SCV间歇性备份故障—无法发现资源组中的实体
适用场景
适用于VMware的SnapCenter 插件(SCV)
问题描述
- 选择控制器备份作业间歇性失败、并显示错误"
Failed to discover entities in resource group" - 在向VMware查询与VM关联的数据存储库属性时、SCV vmcontrol作业日志显示返回异常:
YYYY-MM-DD HH:MM:SSSS DEBUG SCV --- [p474675244-5236] c.n.a.d.VsphereDiscoveryManager : [JobId:XXXX] Found datastore with config file: DS_NAME. Checking for datastore in metadata.YYYY-MM-DD HH:MM:SSSS DEBUG SCV --- [p474675244-5236] c.n.a.d.VsphereDiscoveryManager : [JobId:XXXX] Datastore already populated in metadata, checking for vm: VM_NAMEYYYY-MM-DD HH:MM:SSSS DEBUG SCV --- [p474675244-5236] c.n.a.d.VsphereDiscoveryManager : [JobId:XXXX] Datastore already contains vm in metadataYYYY-MM-DD HH:MM:SSSS WARN SCV --- [p474675244-5236] c.n.a.d.StorageDiscoveryManager : [JobId:XXXX] java.lang.RuntimeException: com.vmware.vijava.vim25.ManagedObjectNotFoundjava.lang.RuntimeException: com.vmware.vijava.vim25.ManagedObjectNotFoundat com.vmware.vijava.vim25.mo.ManagedObject.retrieveObjectProperties(ManagedObject.java:158)at com.vmware.vijava.vim25.mo.ManagedObject.getCurrentProperty(ManagedObject.java:179)at com.vmware.vijava.vim25.mo.ManagedObject.getManagedObjects(ManagedObject.java:221)at com.vmware.vijava.vim25.mo.ManagedObject.getManagedObjects(ManagedObject.java:268)at com.vmware.vijava.vim25.mo.ManagedObject.getDatastores(ManagedObject.java:273)at com.vmware.vijava.vim25.mo.VirtualMachine.getDatastores(VirtualMachine.java:60)at com.netapp.aegis.vsphere.VirtualMachineService.getDatastoresForVM(VirtualMachineService.java:1623)
