跳转到主内容
如果默认网关不能接插,选择控制阀启动过程将等待输入
适用场景
适用于 VMware vSphere (选择控制阀)的 SnapCenter 插件
问题描述
  • 选择控制阀启动过程等待输入:
Checking network configuration. Please wait...
Unable to reach gateway at '<IP address>'.
The network configuration has errors. Specified attributes may be invalid.
Are you sure you want to use these settings? [n]:
  •  在 上述提示符处输入y 会导致错误:
You have chosen to enable appliance with a possible network
configuration error. If you are unable to access the web interface, or it does not
function correctly, please resolve outstanding networking issues and restart this
appliance.
!!! NOT STARTING APPLICATION SERVERS DUE TO CONFIG ERRORS !!!
  • 重新启动选择控制阀设备后出现相同的错误
New to NetApp?
