跳转到主内容
由于已主动暂停ONTAPI、选择控制阀备份或保留失败
109
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • 适用于VMware vSphere的SnapCenter插件(SCV)
  • ONTAP 9.14及更高版本
问题描述
  • 选择控制阀备份无法生成快照、并 出现以下错误:
Error: Snapshot operation failed. ONTAPI has been proactively suspended on this cluster due to inactivity as this feature is deprecated. Use the "system services web ontapi modify" CLI command to un-suspend ONTAPI.
  • Job-<JobID>.log 表示 Get-NcSnapshot  命令失败并显示以下错误、并尝试了多次重试:
[DBG] ex.Message : ONTAPI has been proactively suspended on this cluster due to inactivity as this feature is deprecated. Use the "system services web ontapi modify" CLI command to un-suspend ONTAPI.
[ERR] Failed to run a command Get-NcSnapshot
[ERR] API exception: NetApp.Ontapi.NaUnknownErrnoException: ONTAPI has been proactively suspended on this cluster due to inactivity as this feature is deprecated. Use the "system services web ontapi modify" CLI command to un-suspend ONTAPI.
  at NetApp.DataProtection.Storage.CommandAPI.GetNcSnapshot.ProcessRecord(NcController controller)
[ERR] The result from get-ncsnapshot is null/empty
[ERR] Error: Snapshot enumeration failed, Exception:Failed to run a command Get-NcSnapshot
Object reference not set to an instance of an object.
  • 也可能会出现以下一般性错误:
[ERR] Error: The credentials for the storage system <Storage_Name> is not configured. Resolution: Please check if storage system <Storage_Name> is resolvable or add an entry to etc/hosts file.
New to NetApp?
