跳转到主内容
如果多个 SVM 中存在重复的 NFS IP 地址,则 SCV 备份有时会失败
59
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2008842669</a>
Last Updated:
适用场景
  • 适用于 VMware vSphere ( SCV ) 4.5 的 SnapCenter 插件
  • 多个存储虚拟机( SVM )之间存在重复的 NFS IP 地址
  • NFS 数据存储库的 NFS 导出路径相同
问题描述
  • 选择控制阀有时会选择错误的 SVM 作为备份目标,然后会发生故障
  • vmcontrol_<JOB_ID>.log 显示 SCV 使用重复的 NFS IP 选择了错误的 SVM
DEBUG <HOST> --- [tp1694819250-10] c.n.a.d.VsphereDiscoveryManager      : Datastore type is NFS
DEBUG <HOST> --- [tp1694819250-10] c.n.a.m.DatastoreStorageDetailsCache    : Calling GetNasStorageInfo with NFS LIF <IP> and exportPath <EXPORTPATH>
DEBUG <HOST> --- [tp1694819250-10] c.n.a.m.DatastoreStorageDetailsCache    : Calling GetNasStorageInfo with NFS LIF finished
DEBUG <HOST> --- [tp1694819250-10] c.n.a.m.DatastoreStorageDetailsCache    : Storage footprint found for nfsLif <IP> and exportPath <EXPORTPATH>:  ipAddress null vserverName <SVM> volumeName <VOLUME> junctionPath <JUNCTIONPATH> isLocatedOnFGfalse
  • Job-<JOB_ID>.log 显示对 错误 的 SVM 执行请求 后失败
示例:
[DBG] Running Command New-NcSnapshotMulti controller name : <IP>, vserver : <SVM>
[ERR] API exception
[ERR] Failed to run a command New-NcSnapshotMulti
[DBG] ex.Message : Invalid input. Reason: Operation allowed only on Read_Write (RW) volumes.
[DBG] ex.InnerException.Message : Invalid input. Reason: Operation allowed only on Read_Write (RW) volumes.
[ERR] Error: Snapshot operation failed, Exception:Failed to run a command New-NcSnapshotMulti
注意: 错误可能因配置而异
New to NetApp?
