跳转到主内容
选择控制阀备份或发现失败,无法根据序列号确定LUN
216
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
适用于VMware vSphere的SnapCenter插件(SCV)
问题描述
  •  如果其他非NetApp存储上至少有一个磁盘、则备份数据存储 库和/或VM将失败、即使使用"始终排除所有跨区数据存储库"选项也是如此
    • Error: Unable to discover resources on SCV: Failed to determine LUN based on the serial number
作业日志:
2023-04-25 23:00:03.943 -04:00 [ERR] Failed to determine LUN based on the serial number
2023-04-25 23:00:03.943 -04:00 [ERR] System.Exception: Serial number:<LUN_Serial> not found in the storage systems: <SVM_Name/IP_Address>
   at SnapDrive.Nsf.ServiceProviders.SALPluginFactory.GetLunInfoByQueryingAllStorageSystems(SDGetLunInfoRequest request)
2023-04-25 23:00:03.943 -04:00 [INF] End GetLunInfoByQueryingAllStorageSystems
New to NetApp?
