跳转到主内容
选择控制阀:编辑设置时、无法添加/更新存储系统信息
86
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • 适用于VMware vSphere的SnapCenter插件(SCV) 5.0
  • 适用于VMware vSphere的SnapCenter插件(SCV) 6.0
问题描述
  • 在升级后尝试编辑集群或SVM凭据以更新密码或重新输入密码(以刷新SVM信息)时、集群条目会出现以下错误:
    (X) Failed to add/update storage system(s) information.
    Failed to add/update storage system information:
   Object reference not set to an instance of an object.
  • 删除集群LIF并尝试将其重新添加以绕过此问题描述后、此错误已更改为:
   Failed to add/update storage system information: Failed to connect to storage system <SVM_NAME_OR_IP_ADDR>.\n
   This instance has already started one or more requests. Properties can only be modified before sending the first request.
编辑设置时、无法添加/更新存储系统信息
  • 升级选择控制阀后、无法连接到SVM并列出卷。。
    • Failed to add/update storage system information: Failed to connect to storage system <SVM_NAME_OR_IP_ADDR> .\nInvalid credentials. Please check the username or password
New to NetApp?
