跳转到主内容
4号选择控制器4.8升级显示cURL错误:JSON字符串格式错误
84
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009451145</a>
Last Updated:
适用场景
  • 适用于VMware vSphere的SnapCenter插件(SCV) 4.8
  • 选择控制阀从 4.4或更早版本升级
问题描述
  • 升级到4.8号选择控制阀后登录维护控制台时,系统将再次提示用户输入“名”用户的密码:
We trust you have received the usual lecture from the local System Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
[sudo] password for maint:
  • 提供"maint"用户的密码后、返回以下错误:
sudo: curl: command not found
malformed JSON string, neither array, object, number, string or atom, at
character offset 0 (before “(end of string)”) at /home/maint/scripts/get-token.pl line 11.
  • curl: command not found malformed JSON string 尝试访问维护控制台中的其他菜单时、返回相同的""错误
  • 命令 curl -V 表示未安装卷曲
$ sudo curl -V
New to NetApp?
