跳转到主内容
选择控制阀-恢复VM失败,设备'13'配置无效
68
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>200981394</a>
Last Updated:
适用场景
  • 适用于VMware vSphere的SnapCenter插件[SCV]
  • 虚拟机[VM]
问题描述
  • 在执行Storage vMotion时、如果选择控制阀从装载的快照到目标数据存储库、则将虚拟机还原到备用位置(不同的vCenter Server)将失败。(在任务结束之前)。
  • 选择控制阀在各种日志中报告以下错误信息。
VM控制日志:
2023-05-24 17:08:51.658 ERROR <Hostname> --- [474675244-30367] c.n.a.v.VsphereService          : Invalid configuration for device '13'.
2023-05-24 17:08:51.658 DEBUG <Hostname> --- [474675244-30367] c.n.a.v.MigrationService         : [JobId:1645] Relocate VM Task failed
2023-05-24 17:08:51.661  WARN <Hostname> --- [474675244-30367] c.n.a.r.AbstractRestoreStrategy      : [JobId:1645] Error in relocating VM: <Desintation_VMNAME>
2023-05-24 17:08:51.661 DEBUG <Hostname> --- [474675244-30367] c.n.a.r.AbstractRestoreStrategy      : Clearing the mounted datastore map to prevent unmount. The temporary mounted datastore will need to be manually unmounted from the Backup
2023-05-24 17:08:51.664 ERROR <Hostname> --- [474675244-30367] c.n.a.r.AbstractRestoreStrategy      : ERROR_RESTOREMANAGER_FAILED_TO_RELOCATE_VM : <Desintation_VMNAME>
2023-05-24 17:08:51.664 DEBUG <Hostname> --- [474675244-30367] c.n.a.v.VsphereTaskUtil          : Retrieving task with moref Task:task-163306
2023-05-24 17:08:51.665 DEBUG <Hostname> --- [474675244-30367] c.n.a.v.VsphereService          : [JobId:1645] Connecting to vSphere with session <Session ID>
2023-05-24 17:08:51.699 DEBUG <Hostname> --- [474675244-30367] c.n.a.r.RestoreManager          : Setting restore task as failed
2023-05-24 17:08:51.699 DEBUG <Hostname> --- [474675244-30367] c.n.a.v.VsphereTaskUtil          : Retrieving task with moref Task:task-163306
2023-05-24 17:08:51.699 DEBUG <Hostname> --- [474675244-30367] c.n.a.v.VsphereService          : [JobId:1645] Connecting to vSphere with session <Session ID>
2023-05-24 17:08:51.759 ERROR <Hostname> --- [474675244-30367] c.n.a.s.p.RestoreWorkflowManager     : [JobId:1645] ERROR_RESTOREMANAGER_FAILED_TO_RELOCATE_VM : SKMS-P01-restore
2023-05-24 17:08:51.759 DEBUG <Hostname> --- [474675244-30367] c.n.a.s.p.RestoreWorkflowManager     : created JAXBresponse
2023-05-24 17:08:51.759 DEBUG <Hostname> --- [474675244-30367] c.n.a.s.p.RestoreWorkflowManager     : <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<SmRestoreResponse>
  <Result>
    <_message>ERROR_RESTOREMANAGER_FAILED_TO_RELOCATE_VM : <Desintation_VMNAME></_message>
    <_errorCode>-1</_errorCode>
  </Result>
  <TotalCount>0</TotalCount>
  <DisplayCount>0</DisplayCount>
</SmRestoreResponse>
2023-05-24 17:08:51.759 DEBUG <Hostname> --- [474675244-30367] c.n.a.s.p.RestoreWorkflowManager     : Leaving RestoreWorkflowManager - Restore Phase
WFE日志
2023-05-24 17:08:51.785 DEBUG <Hostname> --- [pool-6-thread-1] c.n.w.r.SCSJobServiceImpl         : Completed updating task on SnapCenter Server.
2023-05-24 17:08:51.785  WARN <Hostname> --- [pool-6-thread-1] c.n.w.m.WorkflowExecutor         : Activity (Restore) of Workflow (WorkflowExecutor), Failed with error: Exception while calling restore on SCV: ERROR_RESTOREMANAGER_FAILED_TO_RELOCATE_VM : Desintation_VMNAME
New to NetApp?
