跳转到主内容
在主机重新启动后, SCSQL 无法进行备份,并显示错误 " 找不到任何资源的存储 " 。
55
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter Server 4.1.x
  • 适用于Microsoft SQL Server的SnapCenter 插件(SCSQL) 4.1.x
  • 适用于Microsoft Windows的SnapCenter 插件(SCW) 4.1.x
问题描述
  • SCSQL/SCW 主机重新启动后, SCSQL 备份失败。
  • SMCore.log 报告以下错误。
Activity 'Creating Snapshot copy' failed with error: Could not find storage for any of the resources
  • SnapDriveSALDebug.log 报告以下错误。
Verbose SAL PID=[XXXX] TID=[XXXX] InitializeONTAP() throw exception: Object reference not set to an instance of an object.
Error SAL PID=[XXXX] TID=[XXXX] Object reference not set to an instance of an object.  at
SnapDrive.Nsf.Core.Storage.StorageConnection.Initialize(SDStorageSystemId storageSystemId)
Error SAL PID=[XXXX] TID=[XXXX] Failed to connect to storage system <SVM> Object reference not set to an instance of an object.
  • Windows Application Event Log 报告以下错误。
SourceName: SnapDriveEventMsgs
EventCode: 528
Message: "SnapDrive failed to set your storage system connection.
Error code : -1
Details : Failed to connect to storage system .
Possible solutions :
1. Check if the firewall blocks the connection.
2. Make sure the Net.Tcp Port Sharing Service is up and running.
3. The credentials are specified correctly."
New to NetApp?
