由于 GetHypervisorHost 失败, SCSQL 备份工作正常,但验证失败 加载虚拟机管理程序信息
适用于
- SnapCenter 服务器
- 适用于 Microsoft SQL Server 的 SnapCenter 插件( SCSQL )
- 适用于 VMware vSphere 的 NetApp SnapCenter 插件( SCV )
- 使用原始设备映射( RDM ) LUN 的虚拟机
问题
- SCSQL 备份工作正常,但验证失败。
- SMCore 作业日志包含错误 "
ErrorCode (-1), ErrorMessage (GetCloneHostInfoActivity failed Found Virtual Machine Disks (VMDKs), but failed to resolve the storage footprint since no vSphere host is configured with SnapCenter.)" 。 - SnapManagerWeb 作业日志包含以下错误。
示例:
2021-0X-XXT10:00:00.0000000+09:00 DEBUG SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] VMwareProvider:BeginInvoke gethostInfo 2021-0X-XXT10:00:00.0000000+09:00 INFO SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] GetHypervisorHost - HostId: 5 2021-0X-XXT10:00:00.0000000+09:00 DEBUG SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] GetHypervisorHost - Exit 2021-0X-XXT10:00:00.0000000+09:00 ERROR SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] ErrorCode (111), ErrorMessage (Found Virtual Machine Disks (VMDKs), but failed to resolve the storage footprint since no vSphere host is configured with SnapCenter.) 2021-0X-XXT10:00:00.0000000+09:00 DEBUG SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] VMwareProvider:EndInvoke gethostInfo
- 对于
RefreshSnapCenter 图形用户界面上的 SCSQL 主机, "" 不起作用。 - "" 的作业日志
Refresh包含以下错误。
示例:
2021-0X-XXT12:00:00.0000000+09:00 DEBUG SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] Start GetVscHostInfoAndUpdateParent 2021-0X-XXT12:00:00.0000000+09:00 DEBUG SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] START VSC Invoking from GetVscHostInfoAndUpdateParent 2021-0X-XXT12:00:00.0000000+09:00 DEBUG SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] virtualization plugin urlhttps://<SCV>:8144/scbr/smcoreplugin/gethostInfo ... 2021-0X-XXT00:00.0000000+09:00 DEBUG SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] Response <?xml version="1.0" encoding="UTF-8" standalone="yes"?><SmGetHostInfoResponse><Result> <_message>Authorization failed, invalid credentials</_message><_errorCode>128</_errorCode></Result><TotalCount>0</TotalCount><DisplayCount>0</DisplayCount></SmGetHostInfoResponse> 2021-0X-XXT00:00.0000000+09:00 DEBUG SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] END VSC Invoking from GetVscHostInfoAndUpdateParent 2021-0X-XXT00:00.0000000+09:00 DEBUG SnapManagerWeb_XXXX PID=[XXXX] TID=[XX] End GetVscHostInfoAndUpdateParent End
