跳转到主内容
SCSQL备份失败、并显示错误"No SQL resource is discovered on the host"
134
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009年261599年</a>
Last Updated:
适用场景
  • 适用于SQL的SnapCenter插件(SCSQL) 4.x
  • Microsoft SQL Always On可用性组(SQL AG)
  • Microsoft SQL故障转移集群实例(SQL FCI)
问题描述
  • SnapCenter 不会在资源窗格中显示属于SQL AG/FCI的数据库可供备份、备份失败并显示错误"No SQL resource is discovered on the host. Check SQL resource(s) state on the host"
  • SnapCenter SQL发现日志会向Access DeniedWMI查询返回一条""错误、用于枚举集群网络资源:
C:\Program Files\NetApp\SnapCenter\SnapCenter Plug-in for Microsoft SQL Server\log\SMSQL_<job ID#>
2022-08-05T07:00:18.2306069-05:00 DEBUG SmSql_<JOB ID#> PID=[XXXX] TID=[66] Resource: SELECT * FROM MSCLUSTER_RESOURCE WHERE Type = "Network Name"
2022-08-05T07:00:19.2149795-05:00 ERROR SmSql_<JOB ID#> PID=[XXXX] TID=[66] An unexpected error occurred while retrieving the Cluster Resource data. [Type:Network Name]
Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
2022-08-05T07:00:19.2931077-05:00 INFO  SmSql_<JOB ID#> PID=[XXXX] TID=[66]  Error when getting FCI resources:
2022-08-05T07:00:19.2931077-05:00 ERROR SmSql_<JOB ID#> PID=[XXXX] TID=[66] An error occurred while retrieving the cluster resources of type 'Network Name'
2022-08-05T07:00:19.2931077-05:00 DEBUG SmSql_<JOB ID#> PID=[XXXX] TID=[66] Check JobID [XXXXX] is marked  cancelled or not in DiscoverResource
2022-08-05T07:00:19.2931077-05:00 DEBUG SmSql_<JOB ID#> PID=[XXXX] TID=[66] Running JobID [XXXXX] is not mark cancelled in DiscoverResource
2022-08-05T07:00:19.3087320-05:00 DEBUG SmSql_<JOB ID#> PID=[XXXX] TID=[66] Start UpdateDiscoveryResults
2022-08-05T07:00:19.3087320-05:00 DEBUG SmSql_<JOB ID#> PID=[XXXX] TID=[66] UpdateDiscoveryResults Update SQL Instances and AGs with Operation Result
2022-08-05T07:00:19.3087320-05:00 DEBUG SmSql_<JOB ID#> PID=[XXXX] TID=[66] End UpdateDiscoveryResults
2022-08-05T07:00:19.3087320-05:00 DEBUG SmSql_<JOB ID#> PID=[XXXX] TID=[66] End DiscoverResource
2022-08-05T07:00:19.3087320-05:00 ERROR SmSql_<JOB ID#> PID=[XXXX] TID=[66] No SQL resource is discovered on the host. Check SQL resource(s) state on the host
New to NetApp?
