跳转到主内容
由于容量池大小而导致的 SCSQL 克隆失败
135
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
适用于
  • 适用于 Microsoft SQL Server 的 SnapCenter 插件 (SCSQL)
  • 采用 SMB 共享的 Azure NetApp Files (ANF)
问题
在 Azure NetApp Files 上使用 SnapCenter 克隆 SQL 数据库时,在 SnapCenter GUI 中会观察到以下错误:
Failed to clone the volume <VOLUME_NAME>:Unable to complete the operation. The capacity pool size of 59373627899904 bytes is too small for the combined volume size of 59910498811904 bytes of the capacity pool. Make sure that the total size of all the volumes in the capacity pool does not exceed the size of the capacity pool.
New to NetApp?
