SCSQL —由于访问权限不足错误、数据库无法进行备份
适用场景
- SnapCenter 服务器
- 适用于 SQL 的 SnapCenter 插件( SCSQL )
问题描述
SCSQL数据库资源不可用于备份、并显示消息
“Not available for backup. DB is not on NetApp Storage, auto-close is enabled or in recovery mode”
在 可选 字段中、而以下项保持true。
- 可选 字段中列出的所有可能原因均无效(即数据库位于 NetApp 存储上,未启用自动关闭且处于联机状态)。
- 正在 SCSQL 主机中枚举用于存放数据库文件的磁盘,此实例的 SC Run as 帐户在 SQL Server 中具有 "sysadmin" 权限。
在中、上述日志可能会显示以下消息
- 在
SmSql_<JOB>.log(SQL Server上的默认路径:<installation_path>\NetApp\SnapCenter\SnapCenter Plug-in for Microsoft SQL Server\log\)中检索作业ID <job>的数据库属性时、SQL资源的发现作业可能会显示权限错误:
DEBUG SmSql_1102 PID=[9568] TID=[4] Fetching Database [<DATABASE_NAME>] properties...
DEBUG SmSql_1102 PID=[9568] TID=[4] FillAGDetails
DEBUG SmSql_1102 PID=[9568] TID=[4] Database Type: User
DEBUG SmSql_1102 PID=[9568] TID=[4] Getting File groups
DEBUG SmSql_1102 PID=[9568] TID=[4] Getting Log Files
ERROR SmSql_1102 PID=[9568] TID=[4] Property Size is not available for Database '[USER_DB]'. This property may not exist for this object, or may not be retrievable due to insufficient access rights.
ERROR SmSql_1102 PID=[9568] TID=[4] Failed to get the details of database <DATABASE_NAME>
ERROR SmSql_1102 PID=[9568] TID=[4] ErrorCode (-1), ErrorMessage (Property Size is not available for Database '[<DATABASE_NAME>]'.This property may not exist for this object, or may not be retrievable due to insufficient access rights. )
- 或者、连接错误也可能会显示类似的消息:
ErrorCode (10010), ErrorMessage (The SQL instance '<HOSTNAME>\<INSTANCE_NAME>' is either stopped or
the user '<DOMAIN>\<ACCOUNT>' does not have required permission to connect.
Error: Failed to connect to server <HOSTNAME>\<INSTANCE_NAME>.)
