跳转到主内容
SCO发现失败、并显示有关缺少数据库文件的PL-SCo-20038
91
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009567777</a>
Last Updated:
适用场景
SnapCenter for Oracle (SCO) 4.8及更高版本
问题描述
数据库发现失败、并显示以下错误:
PL-SCO-20006: Discovery of database files failed for database <ORACLE_SID> on host <HOST_FQDN> with errorPL-SCO-20038: Backup operation cannot proceed because discovered database files do not exist.
使用 LOG_LEVEL=DEBUG in /var/opt/snapcenter/spl/etc/spl.properties (和spld重新启动)时、您可能会在spl日志中看到以下消息:
Execution Monitor Thread [sudo /opt/NetApp/snapcenter/spl/bin/sc_command_executor oracle "test -f /oradata/<DBSID>/<PATH_IN_MOUNT>/DATABASE_FILE.dbf>&& echo true || echo false"] c.n.c.e.ShellResult - EXE-00001: Shell result [0:00:00.087] (Exit Value: 1):
-bash: -c: line 0: syntax error near unexpected token `&&'
-bash: -c: line 0: ` test -f /oradata/<DBSID>/<PATH_IN_MOUNT>/DATABASE_FILE.dbf>&& echo true || echo false'
或者、您可能会收到错误的响应:
Execution Monitor Thread [sudo /opt/NetApp/snapcenter/spl/bin/sc_command_executor oracle "test -f /oradata/<DBSID>/<PATH_IN_MOUNT>/DATABASE_FILE.dbf && echo true || echo false"] c.n.c.e.ShellResult - EXE-00001: Shell result [0:00:00.181] (Exit Value: 0):
false
New to NetApp?
