跳转到主内容
适用于Oracle克隆的SnapCenter 插件失败、并显示错误:PL-SCU-00014:源存储脚本和克隆存储脚本打印不匹配
适用场景
适用于 Oracle 的 SnapCenter 插件( SCO )
问题描述
尝试执行克隆操作时、适用于Oracle克隆的SnapCenter 插件失败、并显示以下错误:
  • PL-SCU-00014:内部错误:源和克隆存储脚本之间的存储资源数量不匹配
以下是SnapCenter 作业日志中的一个示例、该错误可在路径下的spl日志中找到
/<SCOHostName>/<SCOJobID>/var/opt/snapcenter/spl/logs/spl_jobid.log
 2019-10-22T09:00:36.0000587-04:00 INFO qtp1773041202-1051 c.n.p.s.o.CreateClone - SCU-LOG-00504: SCU CreateClone operation started. 2019-10-22T09:00:36.0000587-04:00 DEBUG qtp1773041202-1051 c.n.p.s.o.CreateClone - SCU-LOG-00503: Size of the object SmBackups is 2. 2019-10-22T09:00:36.0000588-04:00 DEBUG qtp1773041202-1051 c.n.p.s.o.CreateClone - SCU-LOG-00503: Size of the object SmClones is 2. 2019-10-22T09:00:36.0000588-04:00 DEBUG qtp1773041202-1051 c.n.p.s.o.CreateClone - SCU-LOG-00512: Attribute isSecondary = false. 2019-10-22T09:00:36.0000589-04:00 DEBUG qtp1773041202-1051 c.n.p.s.m.MetadataModel - SCU-LOG-00503: Size of the object backupComponentInfos is 1. 2019-10-22T09:00:36.0000589-04:00 DEBUG qtp1773041202-1051 c.n.p.s.m.MetadataModel - SCU-LOG-00503: Size of the object smSnapshotInfos is 1. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.m.MetadataModel - SCU-LOG-00526: Processed storage information for the '/oradata/sid' file system of type 'SAN'. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.m.MetadataModel - SCU-LOG-00527: Completed the processing of primary backup. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.m.MetadataModel - SCU-LOG-00503: Size of the object vgMetadataList is 1. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.m.MetadataModel - SCU-LOG-00503: Size of the object linkToFsMap is 0. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.m.MetadataModel - SCU-LOG-00503: Size of the object fileSystemMap is 1. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.m.MetadataModel - SCU-LOG-00527: Completed the processing of co backup. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.o.CreateClone - SCU-LOG-00503: Size of the object smCloneComponentMappings is 1. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.o.CreateClone - SCU-LOG-00503: Size of the object sourceStorageResources is 2. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.o.CreateClone - SCU-LOG-00503: Size of the object cloneStorageResources is 1. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.o.CreateClone - SCU-LOG-00503: Size of the object sourceVirtualResources is 0. 2019-10-22T09:00:36.0000590-04:00 DEBUG qtp1773041202-1051 c.n.p.s.o.CreateClone - SCU-LOG-00503: Size of the object cloneVirtualResources is 0. 2019-10-22T09:00:36.0000591-04:00 ERROR qtp1773041202-1051 c.n.p.s.o.CreateClone - PL-SCU-00014: Internal error: There is a mismatch in the number of storage resources between source and clone storage foot print.
New to NetApp?
