由于Snapshot挂载问题描述、SCO目录编制、验证或克隆失败
适用场景
- 适用于Oracle (SCO) 6.0的SnapCenter插件
- Linux插件中的NFS资源
问题描述
挂载或验证尝试失败,或者无法设置挂载中文件的所有权(从
spl_<JOB_ID>.log ):DEBUG: SCUPlugin: 137: SCU::Utils::Logger::set_error_and_log_with_level(): Failed to execute the command 'chown 54321:54321 /var/opt/snapcenter/sco/backup_mount/SNAPSHOT_NAME/SID_DIR/1', command exited with value 1.或者、如果要编制目录、使RMAN无法找到文件、也可以从SPL日志中找到:
RMAN-03009: failure of catalog command on default channel at DATE TIME
ORA-19625: error identifying file /var/opt/snapcenter/sco/backup_mount/SNAPSHOT_NAME/SID_DIR/1/.../ARCHIVE_LOG_FILE
ORA-27037: unable to obtain file status
Linux-x86_64 Error: 2: No such file or directory
Additional information: 7注意:这种影响很可能是零星的、因为它依赖于SnapCenter服务器、Linux scu插件和ONTAP之间的计时问题。
