SCO 插件在实际提交超时时间内使 cg-commit 失败
适用于
- SnapCenter Server 6.x 使用 ZAPI
- SnapCenter Plug-in for Oracle (SCO) 6.x
- ONTAP 9.16.1
问题
Oracle备份在定期计划的备份期间偶尔会遇到cg-commit超时错误,在SMCore作业日志中可见:
2026-08-25T23:30:20.4543629+02:00 DEBUG SMCore_15095 PID=[10944] TID=[1030] Command: Invoke-NcSystemApi. Storage System: [IP_ADDR]. Version: NetApp Release 9.16.1P11: Thu Jan 15 11:21:38 UTC 2026. Connection Mode: ZAPI. Username: [USERNAME]2026-08-25T23:30:20.4718673+02:00 DEBUG SMCore_15095 PID=[10944] TID=[1030] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Connection timed out此响应在请求的17.5毫秒内出现!
另请注意,此示例显示的时间为CEST时区+2:00h)
从mlog\audit.log中的ONTAP,我们同时看到(此处显示的是UTC时区+0:00h):
Tue Aug 25 2026 21:30:20 +00:00 [kern_audit:info:4154] [traceid:e2aec2b14d175e3a92370f5507f50fe8] 8503e80000581ab6 :: [NODE]:ontapi :: [SNAPCENTER-IP]:[SRC-PORT] :: [SVM-NAME]:[USERNAME] :: <netapp version='1.7' xmlns='http://www.netapp.com/filer/admin' vfiler='[SVM-NAME]'><cg-commit> <cg-id>[CG-PREP-ID]</cg-id></cg-commit></netapp> :: Pending:Tue Aug 25 2026 21:30:20 +00:00 [kern_audit:info:4154] [traceid:e2aec2b14d175e3a92370f5507f50fe8] 8503e80000581ab6 :: [NODE]:ontapi :: [SNAPCENTER-IP]:[SRC-PORT] :: [SVM-NAME]:[USERNAME] :: cg-commit :: Error: Connection timed out计时不如SMCore日志的计时准确,但即使在这里,响应也会在请求到达的同一秒内发送。
