跳转到主内容
SCHANA或SCC Creator插件操作失败、并显示未找到getpid
39
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2010079453</a>
Last Updated:
适用场景
  • 适用于SAP HANA的SnapCenter插件(Linux上的SCHANA) 4.8-4.9P2
  • SnapCenter Creator插件(Linux上的SCC) 4.8-4.9P2
问题描述
hana.log或Sybase.log (<PLUG_IN>、等-来自自动化商店)中发生以下错误:
 ERROR  [pool-#-thread-#] 189 com.netapp.plugincreator.agent.nextgen.plugin.legacyservice.ExecutorImpl -Exception occured - Could not determine PID of wrapper process
在以下行设置包装进程后,包装进程将检查输入文件:
 DEBUG  [pool-#-thread-#] 90 com.netapp.plugincreator.agent.nextgen.plugin.legacyservice.ExecutorImpl -createProcess() - Running wrapper: {[/bin/sh, -c, sudo /opt/NetApp/snapcenter/scc/bin/sccCommandExecutor 'plugins/wrapper/wrapper -wid 205 -pn MAXDB -to 3600']}
 DEBUG  [pool-#-thread-#] 90 com.netapp.plugincreator.agent.nextgen.plugin.legacyservice.WrapperHelperImpl -createRequest() - Wrote request to {/opt/NetApp/snapcenter/scc/plugins/wrapper/in/205+MAXDB+1721812634206+getpid}
 DEBUG  [pool-#-thread-#] 90 com.netapp.plugincreator.agent.nextgen.plugin.legacyservice.WrapperHelperImpl -executeRequest() - Result file: {/opt/NetApp/snapcenter/scc/plugins/wrapper/out/205+MAXDB+1721812634206+getpid}
 DEBUG  [pool-#-thread-#] 90 com.netapp.plugincreator.agent.nextgen.plugin.legacyservice.ExecutorImpl -Logger stdout/stderr running={true}/{true}
 DEBUG  [pool-#-thread-#] 90 com.netapp.plugincreator.agent.nextgen.plugin.legacyservice.ExecutorImpl -Logger stdout/stderr running={false}/{false}
由于缺少输出文件,暂停也会失败,但它声称发生了超时,这是误导性的(日志行的计时甚至不显示中设置的1小时超时 agent.properties,它会在几秒内失败):
 INFO  [pool-#-thread-##] 163 com.netapp.plugincreator.workflow.task.Quiesce -Application quiesce result is empty  from plugin MAXDB. skipping metaData update operation
 ERROR  [pool-#-thread-##] 189 com.netapp.plugincreator.workflow.util.TaskUtil -Operation failed. Reason: The watchdog killed the running operation. Verify that plugins/wrapper/wrapper binary has execute permission set. Increase the WRAPPER_TIMEOUT_IN_MSEC value in agent.properties if operations require more time to complete.
 ERROR  [pool-#-thread-##] 270 com.netapp.plugincreator.workflow.Task -Operation failed. Reason: The watchdog killed the running operation. Verify that plugins/wrapper/wrapper binary has execute permission set. Increase the WRAPPER_TIMEOUT_IN_MSEC value in agent.properties if operations require more time to complete.
 ERROR  [pool-#-thread-##] 118 com.netapp.plugincreator.workflow.task.Quiesce -SCC-00164: Application quiesce for the plug-in [MAXDB] failed with exit code [102] and with error :Operation failed. Reason: The watchdog killed the running operation. Verify that plugins/wrapper/wrapper binary has execute permission set. Increase the WRAPPER_TIMEOUT_IN_MSEC value in agent.properties if operations require more time to complete.
注意: 运行发现(资源刷新)或备份时,在该过程中会启动包装器脚本来监视和输出包装器输入文件,并生成包装器输出文件。
 第一个步骤是获取进程的PID,该PID通常在下的同一个命名文件中返回 scc/plugins/wrapper/out
New to NetApp?
