跳转到主内容
在ASE 16.0更新到PL06后、SAP ASE (Sybase)备份失败并出现静用错误
104
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter服务器(SC) 6.0
  • 适用于SAP ASE的SnapCenter插件(Sybase)
  • SAP ASE 16.0 PL06
  • Sybase Perl模块(SSybase.PM)
问题描述
  • 将ASE 16更新到PL06后、SnapCenter SAP ASE (Sybase)备份开始失败、并出现静修和取消静修错误。
  • 出现以下错误:
SnapCenter UI:
  • 暂停
SCC-00164: Application quiesce for the plug-in [SYBASE] failed with exit code [1] and with error : Process 78 successfully executed QUIESCE DATABASE with HOLD option for tag tagname_PIT. Processes trying to issue an I/O operation on the quiesced database(s) will be suspended until the user executes a QUIESCE DATABASE command with the RELEASE option.
  • 请取消选择
SCC-00161: Application unquiesce for the plug-in [SYBASE] failed with exit code [1] and error : Msg 2222, Level 16, State 1: Server 'PIT', Line 1: QUIESCE DATABASE with RELEASE option failed. No agent process with tag name tagname_master exists or it is being released by another process.
<JobID><Date_Time>日志:
  • 暂停
ERROR  [pool-7-thread-4] 270 com.netapp.plugincreator.workflow.Task -(<Date_Time>) [syb-00013] SYBASE:RUN_CMD: Process 78 successfully executed QUIESCE DATABASE with HOLD option for tag tagname_PIT.
ERROR  [pool-7-thread-4] 270 com.netapp.plugincreator.workflow.Task -(<Date_Time>) Processes trying to issue an I/O operation on the quiesced database(s) will be suspended until the user executes a QUIESCE DATABASE command with the RELEASE option.
INFO  [pool-7-thread-4] 274 com.netapp.plugincreator.workflow.Task -(<Date_Time>) SYBASE:QUIESCE: Quiescing database PIT failed
ERROR  [pool-7-thread-4] 270 com.netapp.plugincreator.workflow.Task -(<Date_Time>) [syb-00004] SYBASE:QUIESCE: Quiescing databases failed
ERROR  [pool-7-thread-4] 118 com.netapp.plugincreator.workflow.task.Quiesce -SCC-00164: Application quiesce for the plug-in [SYBASE] failed with exit code [1] and with error :
  • 请取消选择
ERROR  [pool-7-thread-5] 270 com.netapp.plugincreator.workflow.Task -(<Date_Time>) [syb-00013] SYBASE:RUN_CMD: Msg 2222, Level 16, State 1:
ERROR  [pool-7-thread-5] 270 com.netapp.plugincreator.workflow.Task -(<Date_Time>) Server 'PIT', Line 1:
ERROR  [pool-7-thread-5] 270 com.netapp.plugincreator.workflow.Task -(<Date_Time>) QUIESCE DATABASE with RELEASE option failed. No agent process with tag name tagname_master exists or it is being released by another process.
INFO  [pool-7-thread-5] 274 com.netapp.plugincreator.workflow.Task -(<Date_Time>) SYBASE:UQUIESCE: Unquiescing database master failed
ERROR  [pool-7-thread-5] 270 com.netapp.plugincreator.workflow.Task -(<Date_Time>) [syb-00005] SYBASE:UNQUIESCE: Unquiescing databases failed
ERROR  [pool-7-thread-5] 118 com.netapp.plugincreator.workflow.task.UnQuiesce -SCC-00161: Application unquiesce for the plug-in [SYBASE] failed with exit code [1] and error :
  • 包装机
DEBUG  [pool-2-thread-3] 90 com.netapp.plugincreator.agent.nextgen.plugin.legacyservice.LegacyServiceImpl -logExceptionAndGenerateResult() - Failed due to Execption. Reason: {The watchdog killed the running operation. Verify that plugins/wrapper/wrapper binary has execute permission set. Increase the WRAPPER_TIMEOUT_IN_MSEC value in agent.properties if operations require more time to complete.}
ERROR  [pool-2-thread-3] 195 com.netapp.plugincreator.agent.nextgen.executionmanager.OperationExecutorImpl -null
java.lang.reflect.InvocationTargetException: null
ERROR  [pool-7-thread-8] 189 com.netapp.plugincreator.workflow.util.TaskUtil -Operation failed. Verify that plugins/wrapper/wrapper binary has execute permission set. Increase the WRAPPER_TIMEOUT_IN_MSEC value in agent.properties if operations require more time to complete.
ERROR  [pool-7-thread-8] 270 com.netapp.plugincreator.workflow.Task -Operation failed. Verify that plugins/wrapper/wrapper binary has execute permission set. Increase the WRAPPER_TIMEOUT_IN_MSEC value in agent.properties if operations require more time to complete.
ERROR  [pool-7-thread-8] 118 com.netapp.plugincreator.workflow.task.AppCleanupTask -SCC-00185: Cleanup for plug-in [SYBASE] failed with exit code [102] and error:
ERROR  [pool-2-thread-5] 202 com.netapp.plugincreator.agent.nextgen.plugin.legacyservice.ExecutorServiceImpl -Executor for wid={1}, plugin={SYBASE} has been stopped externally or quit due to inactivity.
DEBUG  [pool-2-thread-5] 90 com.netapp.plugincreator.agent.nextgen.plugin.legacyservice.LegacyServiceImpl -logExecutorErrorAndGenerateResult() - Failed since executor was outdated.
New to NetApp?
