跳转到主内容
将虚拟机还原到原始位置失败、并显示"VM not found"
55
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009年400249</a>
Last Updated:
适用场景
适用于VMware vSphere的SnapCenter插件(SCV)
问题描述
  • VM的选择控制阀恢复作业失败、并显示错误:
    Error: Exception while calling restore on SCV: Error occured while calling SCV: Server Error
  •  选择控制阀恢复作业的vCenter任务停留在50%处
  • vmcontrol_<JobID>.log 报告 VM not found
c.n.a.r.AbstractRestoreStrategy      : Registering the VM
c.n.a.v.VsphereService                   : [JobId:<JobID>] Connecting to vSphere with session XXXXXXXX
c.n.a.v.VsphereInventoryService          : vm is null; checking to see if it is a template:
c.n.a.v.VsphereInventoryService          : Searching all virtual machine managed entities
c.n.a.v.VsphereInventoryService          : [JobId:<JobID>] VM not found, setting as null
  • vpxd.log 在vCenter上、 ESXi主机报告错误:
info vpxd[XXXXX] [Originator@XXXX sub=vpxLro opID=XXXXXXXX] [VpxLRO] -- BEGIN task-XXXX -- group-vXXXX -- vim.Folder.registerVm -- XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX(XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX)
info vpxd[XXXXX] [Originator@XXXX sub=VdbOpJournal opID=XXXXXXXX] Added new journal id=XXX type=1
info vpxd[XXXXX] [Originator@XXXX sub=vpxLro opID=XXXXXXXX-01] [VpxLRO] -- BEGIN lro-XXXXXXXX -- group-vXXXX -- vim.Folder.registerVm -- XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX(XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX)
warning vpxd[XXXXX] [Originator@XXXX sub=AuthorizeManager opID=XXXXXXXX] Privilege check for entity datacenter-XXXX, privilege System.Read made on null session. Backtrace N7Vmacore9ExceptionE(Privilege check in null session)
--> [context]XXXXXXXXXXX[/context]
info vpxd[XXXXX] [Originator@XXXX sub=Invt opID=XXXXXXXX-01-XXXXXXXX] Started call to update entity state moId on host; [vim.HostSystem:host-XXXX,<HOST_NAME>], store: (vm, 60), v: XXXXXXXX:vm-XXXX:XXXXXXXX, callId: 5
warning vpxd[XXXXX] [Originator@XXXX sub=vmmoVm opID=XXXXXXXX-01-XXXXXXXX] Setting VM [vim.VirtualMachine:vm-XXXX,<VM_NAME>] numCpu to default 1
warning vpxd[XXXXX] [Originator@XXXX sub=vmmoVm opID=XXXXXXXX-01-XXXXXXXX] Setting VM [vim.VirtualMachine:vm-XXXX,<VM_NAME> memory size to default 32MB
warning vpxd[XXXXX] [Originator@XXXX sub=vmomi.soapStub[XX] opID=TaskLoop-host-XXXX] SOAP request returned HTTP failure; <<io_obj p:0x00007fcedd02b5c8, h:35, <UNIX ''>, <UNIX '/var/run/envoy-hgw/hgw-pipe'>>, /hgw/host-XXXX/vpxa>, method: waitForUpdates; code: 500(Internal Server Error)
error vpxd[XXXXX] [Originator@XXXX sub=Invt opID=XXXXXXXX-01] Failed to update entity state moId on host; [vim.HostSystem:host-XXXX,<HOST_NAME>], store: (vm, 60), v: XXXXXXXX:vm-XXXX:XXXXXXXX, e: XXXXXXXX(Fault cause: vim.fault.InvalidState
New to NetApp?
