在 WSFC 中注册备份和应用 SCW 备份作业的保留任务失败
适用于
- SnapCenter 适用于 Microsoft Windows 的插件 (SCW)
- Windows Server 故障转移群集 (WSFC)
问题
- 错误注册 SCW 备份作业的备份和应用保留任务
Backup Registration : RegisterBackupEntities failed : BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo
SnapManagerWeb.log显示Cannot find object '<HOST><FILESYSTEM_PATH>:\' from database
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] FillBackupMetaData started
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] Components:1, Successful:1 & Failed:0
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] Cannot find object '<HOST><FILESYSTEM_PATH>:\' from database
ERROR SnapManagerWeb_28 PID=[5424] TID=[5] System.NullReferenceException: Object reference not set to an instance of an object.
at SnapManager.SMSDAL.BackupMetadataMapper.GetBackupComponentInfo(SmRequest request, SmBackupComponentInfo bci, nsm_BackupToObjects_map& nsm_bom, Int64 userId, Boolean isMigrationRequest, Boolean updateSecondaryDetails)
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] Object reference not set to an instance of an object.
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] GetBackupComponentInfo - <HOST><FILESYSTEM_PATH>:\
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] FillBackupMetaData Done
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] MapSMBackupToEntities ended
ERROR SnapManagerWeb_28 PID=[5424] TID=[5] ErrorCode (-1), ErrorMessage (RegisterBackupEntities failed : BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo )
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] RegisterBackupEntities failed : BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] RegisterResourceOwner - <HOST><FILESYSTEM_PATH>:\
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] Unable to find in nsm_sm_object
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] RegisterBackupEntities failed (PrimaryBackup): RegisterBackupEntities failed : BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo
- <HOST> 即使在执行 刷新磁盘 后,仍未在 主机 > 磁盘 中列出
