跳转到主内容
在将SC 5.0升级到6.0后、具有复制功能的Oracle备份失败
68
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter服务器(SC) 6.0
  • 适用于Oracle数据库的SnapCenter插件(SCO) 6.0
问题描述
将SC和SCO从5.0升级到6.0后、启用了SnapMirror / SnapVault复制的所有Oracle备份作业都失败、并显示以下错误:
  • SnapCenter UI:
Activity 'Cloning Resources' failed with error: Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
Object reference not set to an instance of an object.
Activity 'Cleanup Post Cataloging' failed with error: Exception of type 'System.Exception' was thrown.
Activity 'Post Cataloging' failed with error: Exception of type 'System.Exception' was thrown.
Activity 'Preparing for Cataloging' failed with error: Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
  • <JobID>_SMC.log <Date_Time>:
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] Command: Invoke-NcCli. Storage System: <Storage_Name_IP>. Version: NetApp Release 9.13.1P6: Tue Dec 05 16:06:25 UTC 2023. Connection Mode: ZAPI. Username: vsadmin. Storage added as <VServer_Name>.
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [400]: Specified Vserver not found
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] Invoking Invoke-NcCli command-done
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] Volume clone create Failed, Exception: Failed to create the volume clone.
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] Volume clone create Failed, Inner Exception:
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] --VolumeManagementServiceProvider::CreateVolumeClone
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] Failed to create the volume clone.
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] --NFSMountStrategy::CloneResources
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] mount snapshot failed Failed to mount storage resource, error is Failed to create the volume clone.
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] Exception in clone storage Mount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] ErrorCode (-1), ErrorMessage (Mount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] Activity name: Cloning snapshot <Snapshot_Name>: -1 - Mount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] Storage cloning failed
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] Exception in PerformClone Mount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] STACKTRACE   at SnapMgrCoreService.Workflows.Activities.CloneStorageAndVirtualResource.performClone(Dictionary`2 backupMap, Dictionary`2 storageFootPrintMap, SmWorkflowContext workflowContext, SmRequest request, Dictionary`2 backupToSnapshotMap) inner exception
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] PerformClone exit
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] Exception in CloneVirtualandStorageResource Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
  at SnapMgrCoreService.Workflows.Activities.CloneStorageAndVirtualResource.Execute(SmWorkflowContext workflowContext, SmRequest request) Inner exception
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] ErrorCode (-1), ErrorMessage (Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
  • <Date_Time>日志<JobID>:
DEBUG: SCUPlugin: SCU::HostStorage::Device::Linux::SCSIDevice::_get_iscsi_initiators(): Retrieving iSCSI initiators of this host
ERROR: SCUPlugin: 87: SCU::Utils::Logger::set_and_log_error(): Failed to open the file '/etc/iscsi/initiatorname.iscsi': No such file or directory.
DEBUG: SCUPlugin: 87: SCU::Utils::GenericUtil::log_and_throw_with_log_level(): Failed to open the file '/etc/iscsi/initiatorname.iscsi': No such file or directory.
DEBUG: SCUPlugin: SCU::HostStorage::Device::Linux::SCSIDevice::_get_fc_initiators(): Retrieving FC Initiators of this host
DEBUG: SCUPlugin: 129: SCU::Utils::GenericUtil::log_and_throw_with_log_level(): Failed to open the directory '/sys/class/fc_host': No such file or directory.
New to NetApp?
