跳转到主内容
由于缺少密码套件,客户端在通过 IBM Java 运行时可能无法访问 NetApp 服务
29
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>1087590</a>
Last Updated:
适用场景
的所有版本:
  • SnapCenter Creator 插件
  • 适用于 Oracle 的 SnapCenter 插件( SCO )
  • 适用于 SAP HANA 的 SnapCenter 插件( SCHANA )
  • 适用于 UNIX 的 SnapCenter 插件( SCU-In )
  • SnapCreator Framework ( SCF ) 3.4
问题描述
在使用 Snap Creator 的浏览器或客户端日志中显示错误消息:
ERR_SSL_PROTOCOL_ERROR
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
SSL_ERROR_NO_CIPHER_OVERLAP
SnapCenter 图形用户界面中的主机条目显示 "Services stopped" ,即 SMCore_<JOB>.log 从安装作业下载的日志中显示:
Error in invoking SCC RestEndpoint EnablePlugin : Plug-in host service is not available.
Run 'systemctl start scc' on the host machine to start the host service.
Check if the Plugin Service is down or not reachable.
/var/log/snapcenter/spl/logs/spl_0.log 显示:
Caused by: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
at com.ibm.jsse2.g.a(g.java:58)
at com.ibm.jsse2.g.a(g.java:4)
at com.ibm.jsse2.ba.a(ba.java:221)
at com.ibm.jsse2.g$c.consume(g$c.java:19)
at com.ibm.jsse2.ba.a(ba.java:195)
at com.ibm.jsse2.aZ.a(aZ.java:36)
at com.ibm.jsse2.bi.b(bi.java:219)
at com.ibm.jsse2.bi.f(bi.java:317)
at com.ibm.jsse2.bi.a(bi.java:218)
at com.ibm.jsse2.bi.startHandshake(bi.java:212)
New to NetApp?
