跳转到主内容
NetApp连接VMDK失败、并在执行选择控制阀恢复作业期间出现错误"重新配置VM任务失败"
341
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
适用于VMware vSphere的SnapCenter插件(SCV)
问题描述
  • 在选择控制阀恢复作业期间、NetApp连接VMDK失败并显示ERROR:- Reconfig VM Task failed
  • vmcontrol_<JOB_ID>.log vmcontrol_jetty_server.log 显示了 ERROR:- Reconfig VM Task failed
ERROR <HOST> --- [    Thread-88] c.n.a.v.VirtualMachineService       : [JobId:<JOB_ID>] ERROR:- Reconfig VM Task failed: XXXXXXXXXXXXXXXXX
ERROR <HOST> --- [    Thread-88] c.n.a.r.VmdkRestoreManager         : [JobId:<JOB_ID>] Error attaching VMDK to Virtual Machine <VM>"
ERROR <HOST> --- [    Thread-88] c.n.a.s.AegisApiServiceImpl        : Error attaching VMDK to Virtual Machine <VM>"
INFO  SCV root com.netapp.nvpf.api.model.ApiException: ERROR:- Reconfig VM Task failed: XXXXXXXXXXXXXXXXX
INFO  SCV root    at com.netapp.aegis.vsphere.VirtualMachineService.addExistingDiskToVm(VirtualMachineService.java:560)
INFO  SCV root    at com.netapp.aegis.restore.VmdkRestoreManager.attachVmdkFromBackupUsingVmdkFilePath(VmdkRestoreManager.java:364)
INFO  SCV root    at com.netapp.aegis.restore.VmdkRestoreManager.attachVmdksToVM(VmdkRestoreManager.java:311)
INFO  SCV root    at com.netapp.aegis.server.AegisApiServiceImpl$6.run(AegisApiServiceImpl.java:1273)
INFO  SCV root    at java.lang.Thread.run(Thread.java:748)
INFO  SCV root    at com.netapp.aegis.vsphere.VirtualMachineService.addExistingDiskToVm(VirtualMachineService.java:568)
INFO  SCV root com.netapp.nvpf.api.model.ApiException: ERROR:- Reconfig VM Task failed: XXXXXXXXXXXXXXXXX. You can manually attach the disk from the cloned datastore(s). Add the scsi controllers manually and try again.
INFO  SCV root    at com.netapp.aegis.restore.VmdkRestoreManager.attachVmdksToVM(VmdkRestoreManager.java:334)
New to NetApp?
