跳转到主内容
NDB备份间歇性失败、并显示错误"Volume "xxxx" does not exist in Vserver "xxxx"。原因:条目不存在。"
14
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2008508446</a>
Last Updated:
适用场景
NetApp Data Broker (NDB) 1.0/1.0.1
问题描述
  • 在NDB备份期间、如果API因某些原因而出现故障、则在重试API时、指定的Vserver名称将不正确。
  • 这将发生原因 错误""Volume "xxxx" does not exist in Vserver "xxxx". Reason: entry doesn't exist.
例如Volume_A、卷""位于"SVM_A"中、但在重试API时、错误地将其指定为"SVM_B"。
YYYY-MM-DD HH:MM:SS.XXX +09:00 [ERR] API exception
YYYY-MM-DD HH:MM:SS.XXX +09:00 [ERR] Failed to run a command New-NcSnapshotMulti
YYYY-MM-DD HH:MM:SS.XXX +09:00 [DBG] ex.InnerException.InnerException.Message : An error occurred while sending the request. Unable to read data from the transport connection: Broken pipe.
YYYY-MM-DD HH:MM:SS.XXX +09:00 [DBG] ex.InnerException.Message : Volume "Volume_A" does not exist in Vserver "SVM_B". Reason: entry doesn't exist.
YYYY-MM-DD HH:MM:SS.XXX +09:00 [DBG] No retry condition match found or max retry reached. Throwing error Volume "Volume_A" does not exist in Vserver "SVM_B". Reason: entry doesn't exist.
New to NetApp?
