跳转到主内容
升级到SnapCenter 5.0后、Exchange备份失败、并显示"VSS_E_Provider_vet"错误
138
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009970546</a>
Last Updated:
适用场景
  • SnapCenter服务器(SC) 5.0
  • 适用于Microsoft Exchange Server (SCE) 5.0的SnapCenter插件
问题描述
将SnapCenter和(SCE)插件升级到5.0后,SCE备份开始失败,并出现以下错误:
SCE_<JobID_Date_Time>.log
Verbose SCE PID=[<PID>] TID=[<TID>] ++VSSRequestor::LoopWait
Verbose SCE PID=[<PID>] TID=[<TID>] status != aysnc_pending
Error SCE PID=[<PID>] TID=[<TID>] Operation failed [Error code: -2147212538]
Verbose SCE PID=[<PID>] TID=[<TID>] --VSSRequestor::LoopWait
Error SCE PID=[<PID>] TID=[<TID>] Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO]
Verbose SCE PID=[<PID>] TID=[<TID>] --VSSRequestor::CreateVssSnapshot
Error SCE PID=[<PID>] TID=[<TID>] Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] [Error Code: -2147212538] [VSS_E_PROVIDER_VETO]
Verbose SCE PID=[<PID>] TID=[<TID>] --VSSRequestor::Backup
Verbose SCE PID=[<PID>] TID=[<TID>] sceBackupInfoList.Count = 0
Verbose SCE PID=[<PID>] TID=[<TID>] Releasing backup lock
Error SCE PID=[<PID>] TID=[<TID>] Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] Possible solution: Please check if there is adequete space available on the LUNs.
SMCore_<JobID_Date_Time>.log
ERROR SMCore_<Job_ID> PID=[<PID>] TID=[<TID>] ErrorCode (-1), ErrorMessage (Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] Possible solution: Please check if there is adequete space available on the LUNs.)
ERROR SMCore_<JobID> PID=[<PID>] TID=[<TID>] Activity - Creating Backup, Failed with error : Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] Possible solution: Please check if there is adequete space available on the LUNs.
ERROR SMCore_<JobID> PID=[<PID>] TID=[<TID>] ErrorCode (109), ErrorMessage (The following activities failed:Creating Backup,Renaming VSS Snapshot,Creating Snapshot copy for log backup,Registering Backup and Applying Retention,Up To The Minute Retention. Please check the activities for detailed error message.)
New to NetApp?
