跳转到主内容
SnapCenter插件与具有路由路径的SnapCenter服务器之间的连接丢失
3
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter 服务器
  • 适用于SQL的SnapCenter插件(SCSQL)
  • 适用于Exchange的SnapCenter插件(SCE)
  • 适用于Oracle的SnapCenter插件(SCO)
问题描述
连接会随机中断一段时间、从而导致无法更新回SnapCenter服务器、例如从SMCore日志进行更新:
DEBUG SMCore_<JOB> PID=[<Process>] TID=[<Thread>] RemoteUrl: https://<SNAPCENTER_FQDN>:8146/BackupService.svc/DeleteBackup
ERROR SMCore_<JOB> PID=[<Process>] TID=[<Thread>] WebException Encountered, Response null
ERROR SMCore_<JOB> PID=[<Process>] TID=[<Thread>] Exception in method: Invoke.
System.Net.WebException: The underlying connection was closed: A connection that was expected to be kept alive was
closed by the server. ---> System.IO.IOException: Unable to read data from the transport connection:
An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException:
   at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
(在本例中为备份删除)请求已发送、但连接在两分钟后断开。
从"RemoteURL "行的时间戳到下一行的"Exception in method "、都可以看到这种情况。
可以看到的另一个错误、例如、在仍在"运行"的验证作业的详细信息视图中、可能是:
The underlying connection was closed: An unexpected error occurred on a receive.
New to NetApp?
