跳转到主内容
升级到SnapCenter 5.0/5.0P1/6.0后、备份作业失败
146
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter服务器[SC] 5.0、5.0P1或6.0
  • 适用于Windows的SnapCenter插件[SCW]
  • 适用于SQL的SnapCenter插件[SCSQL]
  • ONTAP FSx 9.14.1/9.15.1.
  • REST API
  • Storage Virtual Machine [SVM]
  • 自定义创建的SVM角色。
  • PSTK - ONTAP PowerShell 工具套件
问题描述
  • 升级到5.0或5.0P1版后、SnapCenter备份失败。
  • SMCore日志显示以下条目:
SMCore_JobID.log
2024-07-11T13:06:13.5199782+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] --StorageSystemManager::GetStorageSystemIdFromCache
2024-07-11T13:06:13.5199782+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] Volumes to be snaped: MSSQL_data,MSSQL_logs
2024-07-11T13:06:13.5199782+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] Storage system id: svm01-primary
2024-07-11T13:06:13.5199782+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] Getting a connection from pool
2024-07-11T13:06:13.5199782+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] Use RBAC pool.
2024-07-11T13:06:13.5199782+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] INFO: Retry interval config setting not found.
2024-07-11T13:06:13.5199782+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] --ConfigManager::GetConfigSettingRetryInterval
2024-07-11T13:06:13.5199782+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] Command: New-NcSnapshotMulti. Storage System: 198.19.255.63. Version: NetApp Release 9.14.1P5: Sat May 18 19:42:16 UTC 2024. Connection Mode: REST
2024-07-11T13:06:13.5850650+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [403]: not authorized for that command
2024-07-11T13:06:13.5850650+00:00 DEBUG SMCore_61 PID=[4700] TID=[40] No retry condition match found or max retry reached. Throwing error, The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [403]: not authorized for that command
2024-07-11T13:06:13.5891080+00:00 ERROR SMCore_61 PID=[4700] TID=[40] Create snapshot 'test1_PRODSQL_07-11-2024_13.06.11.9878_1' failed: Snapshot operation failed. [403]: not authorized for that command.
2024-07-11T13:06:13.5891080+00:00 ERROR SMCore_61 PID=[4700] TID=[40] ErrorCode (-1), ErrorMessage (Create snapshot 'test1_PRODSQL_07-11-2024_13.06.11.9878_1' failed: Snapshot operation failed. [403]: not authorized for that command. )
New to NetApp?
