跳转到主内容
MaxDB客户端上的SnapCenter备份错误: javax.xml.bind.jaxbElement
6
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2010070464</a>
Last Updated:
适用场景
  • SnapCenter
  • 适用于MaxDB的SnapCreator Framework插件
  • SAP MaxDB
问题描述
备份期间MaxDB客户端出错: Problem with writing the data, class javax.xml.bind.JAXBElement, ContentType: application/xml
SnapCenterJobLog:
PID=[5028] TID=[108] Command starts: Invoke-NcEmsAutosupportLog - -StorageSystem <storage name> -AppVersion 4.8 -EventSource SnapCenter Software -Category Error -<ComputerName> -EventDescription Backup(SC_BACKUP_TYPE)BackupType(Snapshot-Based) Job[779316], <Hostname>, HostOS[LINUX], Application name[MAXDB], WorkflowCompletionTime[0 Days:0 Hours:0 Minutes:10 Seconds ], PluginCode[SCC] , <Dataset[..._MAXDB_DPG]>, ResourceType, Status[Completed with Errors], [Problem with writing the data, class javax.xml.bind.JAXBElement, ContentType: application/xml] -EventId 1002 -LogLevel 3 -AutoSupport True
SnapCenterJobLogs_BackupLog:
2024-06-21T14:47:33.0000249+02:00 ERROR [pool-...] 195 com.netapp.plugincreator.common.restclient.SMSClientImpl -Error in sending requestjavax.ws.rs.ProcessingException: java.net.SocketTimeoutException: SocketTimeoutException invoking https://..../JobStatusService.svc/UpdateJobStatus: connect timed out
2024-06-21T14:47:35.0000484+02:00 ERROR [pool-7-thread-3] 195 com.netapp.plugincreator.common.restclient.SMSClientImpl -Error in sending request
javax.ws.rs.ProcessingException: Problem with writing the data, class javax.xml.bind.JAXBElement, ContentType: application/xml
at org.apache.cxf.jaxrs.client.AbstractClient.reportMessageHandlerProblem(AbstractClient.java:846)
at org.apache.cxf.jaxrs.client.AbstractClient.writeBody(AbstractClient.java:529)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:750)
Caused by: javax.ws.rs.InternalServerErrorException: HTTP 500 Internal Server Error
2024-06-21T14:48:24.0000001+02:00 ERROR [pool-7-thread-6] 118 com.netapp.plugincreator.workflow.task.AutoSupportTask -SCC-WORKFLOW-00085: Unable to update datamining table for jobId [779316] on SnapCenter Server
New to NetApp?
