跳转到主内容
CSNAPC-989:如果SnapCenter没有文件系统、则LUN无法将现有LUN连接到主机。
933
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
问题描述
当SnapCenter尝试将没有文件系统的现有LUN连接到主机时、连接磁盘向导会显示Failed- Failed to connect disk No disk is found on all nodes 。
  • *在SC外部创建新LUN时、由于以下错误、SC无法连接它:
Failed- Failed to connect disk No disk is found on all nodes.
  • 在实际的</code>中,与<code style="display: !important;">-</code>(使用或不使用<code style="display: !important;">--SharedClient)一起的命令行也会出现相同的错误
Host: Connect-SdStorage : Failed to connect disk No disk is found on all nodes
  • SCW 作业日志(C:\Program Files\Microsoft\Windows\job_logs SnapCenter的NetApp SnapCenter插件)显示如下行。
    示例:
2020-02-12T11:40:10.6716065+00:00 Error SDW PID=[XXXX] TID=[XXXX] Error: Failed to get partition information from disk on node <PLUGIN HOST>
2020-02-12T11:40:10.6716065+00:00 Verbose SDW PID=[XXXX] TID=[XXXX] Error: Failed to get partition information from disk on node <PLUGIN HOST>  at SnapDrive.Nsf.Core.Host.PartitionManager.<>c__DisplayClass13.<ConnectDisk>b__d(String node)
  • 当使用SC图形用户界面主机=>磁盘=>选择主机=> 连接时、作业在创建Windows文件系统阶段失败、并显示错误:
Failed to connect disk. No disk found on all nodes
New to NetApp?
