跳转到主内容
OnCommand Insight Data Warehouse 提取、转换和加载 (ETL) 失败,原因是 MySQL 数据库中的表已满
26
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
适用于
OnCommand Insight Data Warehouse ( DWH ) 7.3.x
OnCommand Insight (OCI) 7.3.x
问题
对 DWH 或 OCI MySQL 数据库的查询失败、并显示一条消息指出临时表已满。查询可以在 ETL 期间或报告生成期间直接运行。
以下是 DWH.log 中的这些错误示例:
2018-11-23 01:47:48,024 INFO [Thread-277 (ActiveMQ-client-global-threads)]
CustomScriptRunnerBean (CustomScriptRunnerBean.java:56) -
E:\Program Files\SANscreen\wildfly\bin\service\amd64>rem
2018-11-23 01:47:48,040 ERROR [Thread-277 (ActiveMQ-client-global-threads)]
CustomScriptRunnerBean (CustomScriptRunnerBean.java:58) - 'name' is not recognized as an internal
or external command,
operable program or batch file.
mysql: [Warning] Using a password on the command line interface can be insecure
ERROR 1114 (HY000) at line 3878: The table 'E:\Program
Files\SANscreen\mysql\tmp\#sql5a8_329_61' is full
Knowledgebase
2019-01-09 02:24:32,743 ERROR [Thread-847 (ActiveMQ-client-global-threads)] JobDispatcherBean
(JobDispatcherBean.java:106) - InventoryJob{name='Inventory: connector 'xxxxxx', 'Jan 9, 2019 2:00
AM'', id=15899, connectorId=7, targetTime=1547020800006, current=true} failed
Caused by: com.netapp.sanscreen.dwh.applications.inventory.InventoryException: Extracting
performance into Table{name='vmdk_performance'} failed (using Context{connector=xxxxxx})
Caused by: com.netapp.sanscreen.dwh.util.SqlShellException: Failed to execute: INSERT IGNORE
INTO dwh_inventory_staging.tmp_vmdk_performance VALUES
Caused by: java.sql.SQLException: The table 'tmp_vmdk_performance' is full
.err 中的此错误的示例为:
2 018-11-23T01:22:17.371221-08:00 809 [ERROR] MySQL: The table 'E:\Program
New to NetApp?
