Unified Manager监控失败、并显示"Error:Data ONTAP reported error code (13130)、message:'重复 条目'"
- 82
- Visibility:
- Public
- Votes:
- 0
- Category:
- active-iq-unified-manager<a>UM</a>
- Specialty:
- om
- Last Updated:
适用场景
- OnCommand Unified Manager (OCUM) 9.5及更低版本
- Active IQ Unified Manager (AIQUM) 9.6倍
问题描述
- 多个集群将报告监控失败
- Unified Manager在Web界面中显示以下错误:
Monitoring failed for cluster clustername. Reason: Cluster cannot be reached. Ensure that there is network connectivity to the cluster and the API has not timed out. The following settings must also be configured correctly for the cluster: hostname or cluster-management IP address, protocol, and port. If the issue persists, contact technical support.
ocum-error.log此文件将包含以下错误:
注意:要查找 ocum-error.log 此文件,请使用知识库文章: What are the notable log files and their respective locations for Active IQ Unified Manager ?
2022-02-17 14:40:50,191 ERROR [oncommand] [...] Failed to Configure EMS for Cluster cluster14367
2022-02-17 14:42:48,204 ERROR [oncommand] [...] Failed to create EMS Destination cluster24823.beta.local on cluster15423. Error: Data ONTAP reported error code (13130), message: 'duplicate entry' (request: '<ems-destination-create><name>cluster24823.beta.local</name><syslog><remote-ip>cluster24823.beta.local</remote-ip></syslog></ems-destination-create>').
2022-02-17 14:42:48,318 ERROR [oncommand] [...] Failed to create EMS Destination cluster24823.beta.local on cluster15423. Error: Data ONTAP reported error code (13130), message: 'duplicate entry' (request: '<ems-destination-create><name>cluster24823.beta.local</name><syslog><remote-ip>cluster24823.beta.local</remote-ip></syslog></ems-destination-create>').
2022-02-17 14:42:48,318 ERROR [oncommand] [...] Failed to Configure EMS for Cluster cluster15423
2022-02-17 14:44:25,413 ERROR [oncommand] [...] Failed to create EMS Destination cluster24823.beta.local on cluster20678. Error: Data ONTAP reported error code (13130), message: 'duplicate entry' (request: '<ems-destination-create><name>cluster24823.beta.local</name><syslog><remote-ip>cluster24823.beta.local</remote-ip></syslog></ems-destination-create>').
