跳转到主内容
无法将ONTAP集群添加到AIQUM、因为ONTAP不接受证书
75
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
适用场景
  • Active IQ Unified Manager (AIQUM) 9.14.
  • ONTAP 9.9.1
  • 可以将其他ONTAP集群添加到AIQUM中
  • 已禁用Cloud Agent
问题描述
  • 将ONTAP集群添加到AIQUM失败、方法是:
Unable to add cluster data source. This can occur if the clocks on the systems are not synchronized and the Active IQ Unified Manager HTTPS certificate start date is later than the date on the cluster, or if the cluster has reached the maximum number of EMS notification destinations.
  • jboss/server_acq.log 指示由于格式不正确、安装AIQUM证书失败
INFO  [default task-55] c.o.s.a.s.AcquisitionFacadeUtil (AcquisitionFacadeUtil.java:106) - [EMS] - Installing Server Certificate
INFO  [default task-55] c.n.o.n.e.EmsZapiManager (EmsZapiManager.java:98) - [EMS ZAPI] - Install Security Certificate - Common Name: <AIQUM_HOST>, Type: server-ca, Certificates: -- omitted --
ERROR [default task-55] c.o.s.a.s.AcquisitionFacadeUtil (AcquisitionFacadeUtil.java:202) - failed to register EMS: : com.netapp.oci.netapp.client.interfaces.data.EmsManagerException: Failed to read the certificate due to incorrect formatting. (errno=61102)
   at deployment.mega-app.ear.server-core.jar//com.netapp.oci.netapp.ems.EmsZapiManager.installSecurityCertificate(EmsZapiManager.java:112)
   at deployment.mega-app.ear.server-core.jar//com.netapp.oci.netapp.ems.EmsManager.installSecurityCertificate(EmsManager.java:79)
   at deployment.mega-app.ear.server-core.jar//com.onaro.sanscreen.acquisition.sessions.AcquisitionFacadeUtil.registerEms(AcquisitionFacadeUtil.java:108)
   at deployment.mega-app.ear.server-core.jar//com.netapp.sanscreen.acquisition.sessions.rest.service.impl.AcquisitionFacadeSessionServiceImpl.addDS(AcquisitionFacadeSessionServiceImpl.java:805)
   at deployment.mega-app.ear.server-api.war//com.netapp.sanscreen.acquisition.sessions.rest.service.impl.AcquisitionFacadeSessionServiceImpl$$FastClassBySpringCGLIB$$92eba61a.invoke(<generated>)
  • /etc/log/mlog/audit.log In ONTAP显示security-certificate-install  ZAPI因格式不正确而失败
[kern_audit:info:2618] 8503e8000016ec3b :: <NODE>:ontapi :: <AIQUM_IP>:63869 :: <NODE>:admin :: <netapp version='1.0' xmlns='http://www.netapp.com/filer/admin' nmsdk_version='9.8P7D1' nmsdk_platform='Windows Server 2022' nmsdk_language='Java'><security-certificate-install><type>server-ca</type><certificate>-----BEGIN CERTIFICATE-----..
[kern_audit:info:2618] 8503e8000016ec3b :: <NODE>:ontapi :: <AIQUM_IP>:63869 :: <NODE>:admin :: security-certificate-install :: Error: Failed to read the certificate due to incorrect formatting.
New to NetApp?
  • 这篇文章对您有帮助吗?
