跳转到主内容
使用".sql"脚本从AIQUM服务器中删除ONTAP集群
597
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
适用于
Active IQ Unified Manager
问题
  • 从 AIQUM UI > General > Storage Management > Cluster Setup > UI Shows 中删除集群
    • Operation == Deletion
    • Operation State == Failed
    • Operation State == In Progress
    • Operation State == Completed
  • 当我们尝试从 AIQUM UI 中删除 ONTAP 集群时,AIQUM 日志不是很有帮助
    • ocumserver.log
    • DEBUG [oncommand] [inventory-change-notify-342] [clustername(incremental@08:22:26.709)|notify|system_health_alert|delete] [o.s.t.jta.JtaTransactionManager] Participating in existing transaction
    • DEBUG [oncommand] [inventory-change-notify-342] [clustername(incremental@08:22:26.709)|notify|system_health_alert|delete] [com.zaxxer.hikari.pool.HikariPool] um-default-data-source - Add connection elided, waiting 6, queue 7
    • ERROR [common-pool-2331] c.o.s.a.f.d.BaseDataSource (DataSourceErrorException.java:246) - clustername [Error retrieving data] - Timed out waiting for cluster, recommend increasing timeout value ([Device name General Device]: Timed out waiting for cluster, recommend increasing timeout value)
  • 无法在 AIQUM 中添加集群。AIQUM GUI 返回错误"集群已存在",这是由 MySQL 数据库中的重复条目引起的。
  • Cloud Agent 已启用且已配置 REST 收集,但 AIQUM 仍继续对受影响的集群执行基于 ZAPI 的收集。
    • Ocumserver.log
    2026-04-28 14:41:55,065 INFO  [oncommand] [org.springframework.jms.listener.DefaultMessageListenerContainer#1-1] [com.netapp.ipc.jms.OCIE_Events] OCIE JMS notification message received: {WarningCount=0, DatasourceName=clustername, DatasourceID=60, Error0_ClusterManagementIP=clustername, PackageName=netappfoundation, TotalReportTime=-1, PollStartTime=1777380083790, ErrorCount=1, Success=false, DurationTime=31263, Error0_Message=Internal Error, TotalZAPITime=-1, NotificationType=PACKAGE_COMPLETED, Error0_Type=INTERNAL_ERROR, UpdateTime=1777380115065, Error0_Port=443, MessageType=PACKAGE_NOTIFICATION, Error0_Zapi=null}
    • AU.log
    2026-04-28 14:56:55,023 ERROR [common-pool-156] c.o.s.a.d.n.b.z.c.n.ClusterBuilder (ClusterBuilder.java:286) - [netappfoundation] clustername - ExecutionException encountered on Builder java.util.concurrent.ExecutionException: java.lang.NullPointerException: storage_shelf key field 'uuid' may not be null.
  • 如果集群已经停用或更改,您可能会看到另一个错误,因为它甚至没有开始采集。
    • Server_mega.log
      • 2019-06-25 07:23:28,595 ERROR [ServerService Thread Pool -- 390] c.n.o.n.e.EmsZapiManager (EmsZapiManager.java:740) - Failed to call system-get-version -- : java.io.IOException: The host [cluster name] not be resolved
    • ocum-error.log
      • 2026-03-31 01:03:46,015 ERROR [oncommand] [reconciliation-0] [c.n.d.c.ClusterStatusListener] Socket connection error for cluster: Cluster-mgmt java.net.ConnectException: Connection timed out: connect
        2026-03-31 01:03:46,015 ERROR [oncommand] [reconciliation-0] [c.n.d.c.ClusterStatusListener] Cluster : Cluster-mgmt is not reachable. Generating cluster not reachable event.
New to NetApp?
