跳转到主内容
OnCommand Unified Manager的Web界面变得缓慢/无响应
225
Visibility:
Votes:
0
Category:
oncommand-unified-manager<a>OCUM</a><a>AIQUM</a><a>1086742</a><a>速度慢/无响应</a>
Specialty:
om
Last Updated:
适用场景
  • OnCommand Unified Manager (OCUM) 9.5及更低版本
  • ActiveIQ Unified Manager (AIQUM) 9.6及更高版本
问题描述
  • OnCommand Unified Manager Web界面变得陈旧、无响应、并停止从其受监控集群收集数据
  • 由于服务器几乎无法正常运行、不会触发事件/警报
  • 重新启动OnCommand 统一管理器( vapp)的虚拟机实例后、此功能会在相对较短的时间内恢复、直到响应速度减慢、需要重新启动为止
  • 在某些情况下 、AIQUM服务可能在重新启动后根本无法启动
在支持包的"jjBoss"文件夹中、查看"au_error###.log"文件中的以下内容:
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (mmap) failed to map 12288 bytes for committing reserved memory.
# Possible reasons:
# The system is out of physical RAM or swap space
# In 32 bit mode, the process size limit was hit
# Possible solutions: Knowledgebase
# Reduce memory load on the system
# Increase physical memory or swap space
# Check if swap backing store is full
# Use 64 bit Java on a 64 bit OS
# Decrease Java heap size (-Xmx/-Xms)
# Decrease number of Java threads
# Decrease Java thread stack sizes (-Xss)
# Set larger code cache with -XX:ReservedCodeCacheSize=
# This output file may be truncated or incomplete.
# # Out of Memory Error (os_linux.cpp:2643), pid=6920, tid=0x00007f30c27e9700
New to NetApp?
