跳转到主内容
将灵活卷转换为灵活组后、AUX副本失败
195
Visibility:
Votes:
0
Category:
active-iq-unified-manager<a>2009047526</a><a>翻译</a>
Specialty:
om
Last Updated:
适用场景
Active IQ Unified Manager 9.9、9.10 (AIQ UM)
Commvault IntelliSnap
问题描述
  • 为了解决空间和性能问题、灵活卷已转换为灵活组
  • 在存储端一切正常、同样在UM数据库中、ID也不会更改
  • 由于订阅已更改、AUX副本不再起作用
UM日志错误 (ocumserver.log)
2022-01-19 14:25:53,717 ERROR [UMserver] [default task-20827] [service.logging.SimpleRemoteLoggingService|logOnServer] [c.n.n.c.u.a.e.ApplicationErrorHandler] Could not set field value [cluster://cluster-SVM1/vol_migrationtest2] value by reflection : [class com.netapp.dfm.entity.protection.StorageServiceNodeMember.volume] setter of com.netapp.dfm.entity.protection.StorageServiceNodeMember.volume; nested exception is org.hibernate.PropertyAccessException: Could not set field value [cluster://cluster-SVM1/vol_migrationtest2] value by reflection : [class com.netapp.dfm.entity.protection.StorageServiceNodeMember.volume] setter of com.netapp.dfm.entity.protection.StorageServiceNodeMember.volume
Commvault作业日志
15120 44e8  02/02 22:18:35 995969 Scheduler  Set pending cause [Error occurred while adding list of snapshots to Dataset id [b78fe472-9db2-4217-86f1-c6c9ac0ae59d:app_type=AIQ_UM,type=storage_service_subscription,uuid=283a9952-584d-49c6-a8ec-abdcd709a1ef], Source Copy [213].  Error Message = [Failed to get subscription list from OnCommand server:[dfm1].Error returned:[13001][No row with the given identifier exists: [com.netapp.dfm.entity.inventory.ontap.storage.FlexVol#676220]]].]::Client [bck1] Application [AuxCopy] Message Id [419430437] Error code [25:37] RCID [0] ReservationId [0].  Level [0] flags [0] id [0] overwrite [0] append [1] CustId[0].
15120 1860  02/02 22:18:35 995969 Scheduler  Set pending cause [Error occurred while replicating snaps [ cluster:SP_2_993508_1019080_1643363351], for storage policy [Cdot_SP_Fileservices] copy [SnapVault] MediaAgent [agent1]:  Backup job [993508]. Failed to get subscription list from OnCommand server:[dfm1].Error returned:[13001][No row with the given identifier exists: [com.netapp.dfm.entity.inventory.ontap.storage.FlexVol#676220]].]::Client [bck1] Application [AuxCopyMgr] Message Id [218104034] Error code [13:226] RCID [0] ReservationId [0].  Level [0] flags [0] id [0] overwrite [0] append [1] CustId[0].
15120 1f3c  02/02 22:18:39 995969 Scheduler  Set pending cause [Error occurred while replicating snaps [ cluster:SP_2_993508_1019080_1643363351], for storage policy [Cdot_SP_Fileservices] copy [SnapVault] MediaAgent [agent1]:  Backup job [993508]. Failed to get subscription list from OnCommand server:[dfm1].Error returned:[13001][No row with the given identifier exists: [com.netapp.dfm.entity.inventory.ontap.storage.FlexVol#676220]].]::Client [bck1] Application [AuxCopyMgr] Message Id [218104034] Error code [13:226] RCID [0] ReservationId [0].  Level [0] flags [0] id [0] overwrite [0] append [1] CustId[0].
API on subscription、subscription member以及conform的结果
<results reason='No row with the given identifier exists: [com.netapp.dfm.entity.inventory.ontap.storage.FlexVol#676243]' errno='13001' status='failed'/>
New to NetApp?
