跳转到主内容
Active IQ Unified Manager 证书再生和导入解决方法指南
762
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
适用于
Active IQ Unified Manager (AIQUM)
回答
解决 Active IQ Unified Manager 证书问题的解决方案指南
  • 操作
如何为 Active IQ Unified Manager 生成和转换签名证书
如何在 ONTAP System Manager 中续订自签名证书
如何使用 ONTAP System Manager 安装或续订 CA 签名的证书
  • 证书输入无效
The certificate input is not valid. Either the Common Name (CN) of the host certificate is not valid or the host certificate does not belong to this host
此证书输入无效。此主机证书的通用名称 (CN) 无效或此主机证书不属于此主机
  •  AIQUM 证书在续订后未在集群上更新
AIQUM 是否在 ONTAP 集群上安装刷新的证书?
  • 证书链问题
Failed to install certificate: A valid full certificate chain from the host certificate to the Certificate Authority's certificate must be provided.
如何修复 Active IQ Unified Manager 的 CA 签名证书的错误证书顺序
AIQUM 的 CA 签名证书缺少根证书或服务器证书
  • 公钥不匹配
Failed to install certificate: Input certificate's public key differs from the existing certificate's public key. The keys must match.
Unified Manager 9.9 之前从外部生成的 CSR
由于缺少外部生成的证书中的私钥或加密的私钥,导入失败
由于在 SAN 字段中指定了 IP 或 localhost,导入失败
