由于违反 EMS 通知目标的最大数量,Active IQ Unified Manager 无法添加 ONTAP 集群
适用于
- Active IQ Unified Manager 9.x
- ONTAP 9
问题描述
- 尝试从集群设置 页面在 Active IQ Unified Manager 中添加 ONTAP 集群数据源失败。
- 提示返回错误消息:
Unable to add data source, which can be caused by reaching the max number of EMS notification destinations in the data source.
或
Unable to add cluster data source. This can occur if the clocks on the systems are not synchronized and the Active IQ Unified Manager HTTPS certificate start date is later than the date on the cluster, or if the cluster has reached the maximum number of EMS notification destinations.
或
ERROR: Server returned HTTP status 500.HTTP error message :{"timestamp":"2024-08-27T05:16:46.971+00:00","status":500,"error":"Internal Server Error","path":"/acquisition-api/server/datasource"}
