跳转到主内容
即使设置了正确的凭据、AIQUM采集单元也会收到身份验证错误
74
Visibility:
Votes:
0
Category:
active-iq-unified-manager<a>ocieau</a><a /><a>2009890634-secure-certifice-delete</a><a />
Specialty:
om
Last Updated:
适用场景
  • Active IQ Unified Manager (AIQUM) 9.12及更高版本
  • ONTAP 9.6及更高版本
  • 已为ONTAP集群启用相互传输层安全(MTLS/相互TLS)
问题描述
  • 尽管集群凭据正确、但由于身份验证错误、采集单元无法从ONTAP收集数据
  • AIQUM信息板显示 Cluster discovery failed. Rediscover the cluster after resolving the issue.
  • 事件 Cluster Monitoring Failed 已触发
  • au.log 显示错误:
ERROR [common-pool-XX] c.o.s.a.d.n.t.z.ZAPIConnection (ZAPIConnection.java:629) - [netappfoundation] <cluster_name> - while executing ZAPIs on datasource: <cluster_name> IP: <cluster_ip> for ZAPI: system-get-version, netapp.manage.NaAuthenticationException: Authorization failed netapp.manage.NaAuthenticationException: Authorization failed
ERROR [common-pool-XX] c.o.s.a.f.d.BaseDataSource (DataSourceErrorException.java:246) - cluster1 [Invalid login credentials] - Failed to log in to the cluster: <cluster_name> ([Device name <cluster_name>]: Failed to login to the cluster.)
  • /etc/log/mlog/apache_logs/apache_error.log 的ONTAP集群显示 用户空的身份验证错误
[auth_basic:error] [pid <pid>:tid <tid>] [client <AIQUM_IP>:<port>] AH01617: user null: authentication failure for "//servlets/netapp.servlets.admin.XMLrequest_filer": Password Mismatch
New to NetApp?
