添加数据源后的采集过程长时间未完成,因为健康轮询失败
适用于
- Active IQ Unified Manager (AIQUM) 9.14+
- ONTAP 9.14+
问题
- 集群发现需要很长时间,最终失败
- AIQUM 的事件管理显示:
Event: Cluster Monitoring Failed.
Monitoring failed for cluster cluster. Reason: Incorrect response from one or more Data ONTAP APIs. Contact technical support.
acquisition/au.log显示:
INFO [common-pool-4105] c.o.s.a.d.n.NetAppOCIEDataSource (NetAppOCIEDataSource.java:217) - [CA] Cloud Agent Baseline response took 600002 ms
ERROR [common-pool-4105] c.o.s.a.d.n.NetAppOCIEDataSource (NetAppOCIEDataSource.java:223) - Timed out waiting for cluster, recommend increasing timeout value
INFO [common-pool-4105] c.o.s.a.d.n.NetAppOCIEDataSource (NetAppOCIEDataSource.java:338) - [] Total poll duration: 600003 ms
INFO [common-pool-4105] c.o.s.a.d.n.NetAppOCIEDataSource (NetAppOCIEDataSource.java:346) - [] -- Finished Poll --
INFO [common-pool-4105] c.o.s.a.f.d.BaseDataSource (BaseDataSource.java:667) - Datasource - 1.2.3.4 is stopped.
ERROR [common-pool-4105] c.o.s.a.f.d.BaseDataSource (DataSourceErrorException.java:246) - 1.2.3.4 [Error retrieving data] - Timed out waiting for cluster, recommend increasing timeout value ([Device name General Device]: Timed out waiting for cluster, recommend increasing timeout value)
INFO [common-pool-4105] c.o.m.h.AUAuditHttpClientManager (AUAuditHttpClientManager.java:74) - Closing datasource audit
INFO [common-pool-4105] c.o.s.a.f.d.BaseDataSource (BaseDataSource.java:311) - [netappfoundation] 1.2.3.4 - Finished acquisition (600058 msecs)
jboss/server_acq.log显示云代理通信事件:
ERROR [default task-3936] c.n.u.CloudAgentConnectionUtil (CloudAgentConnectionUtil.java:102) - deletion of connection agent from datasource failed with error code: 404
INFO [default task-3936] c.n.s.m.AccessHandle (AccessHandle.java:101) - Transitioning state from MAIN to DOWN
ERROR [default task-3936] c.n.s.m.JmsBase (JmsBase.java:261) - Failed to create TextMessage: javax.jms.IllegalStateException: The Session was closed due to an unrecoverable error
OCUMSERVER.log显示:
WARN [oncommand] [reconciliation-0] [c.n.d.c.ClusterStatusListener] Acquisition Failed for cluster : 1.2.3.4 message : Timed out waiting for cluster, recommend increasing timeout value
INFO [oncommand] [reconciliation-0] [c.n.dfm.collector.OcieJmsListener] CONFIG ds=1.2.3.4(8), PollStartTime=1748324314785, UpdateTime=1748324914803, MegaDuration=600003, SystemTime=1748324914822
ERROR [oncommand] [job-451] [refresh(dataSource=1.2.3.4)|forceAcquisition] [com.netapp.dfm.job.JobEngine] Error executing job 641be6841c6a5a33:774b111c:196e5df2fc0:-79e9 task 641be6841c6a5a33:774b111c:196e5df2fc0:-79eb: Errors reported on acquisition with start time 14:38:34.785: [Timed out waiting for cluster, recommend increasing timeout value]
java.lang.RuntimeException: Errors reported on acquisition with start time 14:38:34.785: [Timed out waiting for cluster, recommend increasing timeout value]
