跳转到主内容
AIQUM无法启动采集服务、并显示错误"Failed to start acquAcquisition - failed to load certificates"和WebUI问题
112
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
适用场景
  • Active IQ 统一管理器(AIQUM)
问题描述
  • 尝试启动NetApp Active IQ 采集服务时收到错误
Windows could not start the NetApp Active IQ Acquisition Service on Local Computer.
  • AIQUM服务器中显示"加载集群下拉列表时出错"
  • "Cluster Setup"下的集群列表为空。
  • au.log中、可能存在以下一个或多个错误。
ERROR [WrapperStartStopAppMain] c.o.s.a.f.Main (Main.java:66) - Main - failed to start services: Failed to start acquisition - Failed to load certificates java.io.IOException: DerInputStream.getLength(): lengthTag=109, too big
2021年03月08日17:29:23、630信息[主目录] C.o.c.s.a.x.y.x.y.CertificateDownloader(CertificateDownloader.java:88)-下载并安装IP证书 localhost
2021-03-08 17:29:23,637 INFO  [main] c.o.s.a.f.m.CertificateDownloader (CertificateDownloader.java:125) - certificate was added to key store using alias 'localhost-1
2021-03-08 17:29:23,638 ERROR [main] c.o.s.a.f.m.CommunicationManager (CommunicationManager.java:396) - null java.io.IOException: No space left on device
Wrapped by: com.onaro.sanscreen.acquisition.framework.FrameworkException: Failed to save key store
2021-03-08 17:44:44,586 ERROR [main] c.o.s.a.f.Main (Main.java:162) - Main - Failed to start acquisition - Failed to load certificates java.io.IOException: Short read of DER length
ocumserver.log:
Error from ocum server logs: 2023-05-31 13:31:14,367 INFO  [oncommand] [task-scheduler-8] [c.n.s.service.MemoryMonitorService] AU JVM memory will not be checked for space since enough samples are not available after a JVM restart
日志位置可在 Active IQ Unified Manager 的哪些值得注意的日志文件及其各自的位置中找到?
New to NetApp?
