跳转到主内容
CAIQUM-7119:RHEL8的AIQUM安装程序归档中包含的自述文件包括以下内容:"升级说明不适用于Red Hat Enterprise Linux 8"
98
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
问题描述
  • 已创建此TT以进行文档更正。
  • ActiveIQUnifiedManager-9.XX-el8.zip 中的README 包含以下文本:
To upgrade from a prior version of the software please use the pre-check
command to ensure that all the requirements are met.  The upgrade process
requires several steps, and cannot be performed using yum alone.
Note: Upgrade instructions are not applicable for Red Hat Enterprise Linux 8. You can only install Unified Manager on an RHEL 8 systems, and not upgrade.
New to NetApp?
