跳转到主内容
AIQUM 集群发现状态显示失败,PKIX 路径构建失败
155
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
适用于
  • ActiveIQ Unified Manager (AIQUM) 9.12+
  • 所有平台(Windows / Linux / OVA)
问题
  • 集群操作状态在 AIQUM 中显示为"failed",因为它停止收集数据
  • 重新发现集群失败
  • 通过 AIQUM 为集群执行还原操作失败
  • 如果集群由于此问题而未成功配置,则 仪表板中不会显示任何内容
  • 当卷利用率已超过阈值时,将不再发送卷警报
  • 生成间歇性集群监控事件
  • ocumserver.log中出现的错误:
    • Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    • 2023-10-13 15:14:42,498 ERROR [oncommand] [reconciliation-2] [IP_or_HostName(incremental@15:14:39.135)] [c.n.dfm.collector.OcieJmsListener] Inventory change listener error java.lang.RuntimeException: com.ctc.wstx.exc.WstxUnexpectedCharException: Unexpected character '>' (code 62) expected '='
    • 2023-10-16 00:03:01,881 ERROR [oncommand] [reconciliation-3] [IP_or_HostName(incremental@00:02:57.421)] [c.n.dfm.collector.OcieJmsListener] Inventory change listener error
      java.lang.RuntimeException: com.ctc.wstx.exc.WstxUnexpectedCharException: Unexpected character '&' (code 38) (expected a name start character)
    • 2024-07-24 11:54:07,680 ERROR [oncommand] [reconciliation-3] [IP_or_HostName(incremental@11:54:00.218)] [c.n.dfm.collector.OcieJmsListener] Inventory change listener error
      java.lang.RuntimeException: com.ctc.wstx.exc.WstxParsingException: Duplicate attribute 'id'.
    • 2026-02-10 11:37:12,263 ERROR [oncommand] [reconciliation-8] [IP_or_HostName(incremental@11:31:41.965)] [c.n.dfm.collector.OcieJmsListener] Inventory change listener error
      org.hibernate.HibernateException: Timeout (300000 ms) occurred while trying to generate a new id
    • 2026-04-27 00:18:09,302 ERROR [oncommand] [reconciliation-1] [IP_or_HostName(incremental@00:18:08.927)] [c.n.dfm.collector.OcieJmsListener] Inventory change listener error
      com.netapp.connection.core.OntapRestException: Invalid get collection request with cause: "User is not authorizied."
  • au.log 中看到的其他消息:
    • 2024-04-08 10:33:04,771 INFO  [foundation-poll-0] c.o.s.a.d.n.t.z.ZAPIConnection (ZAPIConnection.java:766) - Inside after checking mutual tls
New to NetApp?
