无法创建CIFS服务器并加入域
适用场景
- ONTAP 9
- CIFS/SMB
- AD (LDAP)
问题描述
- 创建CIFS服务器失败
Error: Machine account creation procedure failed
vserver cifs create -cifs-server <cifs-server> -vserver <vserver> -domain <domain> -ou <ou>
- 日志(secd)报告
Loaded the preliminary configuration.
Successfully connected to ip <ip-address>, port 88 using TCP
Successfully connected to ip <ip-address>, port 389 using TCP
Entry for host-address: <ip-address> not found in the current source: FILES. Ignoring and trying next available source
FAILURE: Unable to SASL bind to LDAP server using GSSAPI: Local error
Additional info: SASL(-1): generic failure: GSSAPI Error: Unspecified GSS failure. Minor code may provide more information (Server not found in Kerberos database)
Unable to connect to LDAP (Active Directory) service on <ad-server> (Error: Local error)
Unable to make a connection (LDAP (Active Directory):<ad-domain>), result: 7643
Retry requested, but the retry window (7000 ms) has expired; giving up. - 检查(在高级模式下)
vserver services name-service getxxbyyy getaddrinfo -node <node> -vserver <vserver> -hostname <hostname> -show-source true
vserver services name-service getxxbyyy getnameinfo -node <node> -vserver <vserver> -ipaddress <ipaddress> -show-source true
