跳转到主内容
ONTAP Select 精简 NFS vmdk 文件大小不断增长
19
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
cloud
Last Updated:
适用场景
  • ONTAP Select
  • NFS
  • VMware
  • Virtual Storage Console (VSC)
问题描述
尽管 OTS 中已回收了可用空间,但精简配置的 NFS VMDK 仍会随着时间的推移而增长:
cluster01--1::> df -h fg*
Filesystem         total    used    avail capacity  Mounted on          Vserver
/vol/fg_nfs/        972GB    621MB   972GB     0%  /fg_nfs           svm1
/vol/fg_nfs/.snapshot    51GB     30MB     51GB     0%  /fg_nfs/.snapshot      svm1
[root@rhel1 ~]# df -h /mnt/fg_vol
Filesystem       Size  Used Avail Use% Mounted on
10.61.79.130:/fg_nfs  973G  622M 973G   1% /mnt/fg_vol
[root@esxi1:~] du -ah /vmfs/volumes/datastore-nfs6/cluster01-01
79.6G  /vmfs/volumes/datastore-nfs6/cluster01-01/cluster01-01_1-flat.vmdk
4.0K   /vmfs/volumes/datastore-nfs6/cluster01-01/cluster01-01_1.vmdk
[root@esxi2:~] du -ah /vmfs/volumes/datastore-nfs7/cluster01-01
90.4G  /vmfs/volumes/datastore-nfs7/cluster01-01/cluster01-01_1-flat.vmdk
4.0K   /vmfs/volumes/datastore-nfs7/cluster01-01/cluster01-01_1.vmdk
New to NetApp?
