跳转到主内容
E系列消耗导致驱动器隔离、从而导致冗余不匹配
4
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
hw<a>2009年264557</a>
Last Updated:
适用场景
NetApp E系列60驱动器架
问题描述
  • E-Series Notification (Isolation of drive causing redundancy mismatch) CRITICAL 警报
  • 从查看时、所有具有受影响磁盘架和抽取的驱动器均显示为最佳状态DRIVESstorage-array-profile。示例:clipboard_edb6c2df40a2679337296e1db309b34bc.png
  • 可以观察到多个MEL事件、下面是一些示例。记下抽取编号以供日后使用。
A:9/25/22, 10:37:10 PM (22:37:10) 18168109 2046 Isolation of drive causing redundancy mismatch - Shelf 99, Drawer 5, Bay 7 - LBA: 0x4e97e600 - SSID: 0x4 = 4 <--CRITICAL
A:9/25/22, 10:37:10 PM (22:37:10) 18168108 2035 Redundancy not consistent - Volume NAME - SSID: 0x4 = 4 - LBA: 0x00000000, Blocks:32768
A:9/25/22, 10:37:09 PM (22:37:09) 18168107 2046 Isolation of drive causing redundancy mismatch - Shelf 99, Drawer 5, Bay 7 - LBA: 0x4e97d200 - SSID: 0x4 = 4 <--CRITICAL
A:9/25/22, 10:37:09 PM (22:37:09) 18168106 2035 Redundancy not consistent - Volume NAME - SSID: 0x4 = 4 - LBA: 0x00000000, Blocks:32768
A:9/25/22, 10:37:06 PM (22:37:06) 18168105 2046 Isolation of drive causing redundancy mismatch - Shelf 99, Drawer 5, Bay 8 - LBA: 0x4ca76600 - SSID: 0x4 = 4 <--CRITICAL
A:9/25/22, 10:37:06 PM (22:37:06) 18168104 2035 Redundancy not consistent - Volume NAME - SSID: 0x4 = 4 - LBA: 0x00000000, Blocks:32768
A:9/25/22, 10:37:03 PM (22:37:03) 18168103 2046 Isolation of drive causing redundancy mismatch - Shelf 99, Drawer 5, Bay 8 - LBA: 0x4ca6a850 - SSID: 0x4 = 4 <--CRITICAL
A:9/25/22, 10:37:03 PM (22:37:03) 18168102 2035 Redundancy not consistent - Volume NAME - SSID: 0x4 = 4 - LBA: 0x00000000, Blocks:32768
A:9/25/22, 10:36:49 PM (22:36:49) 18168101 2046 Isolation of drive causing redundancy mismatch - Shelf 99, Drawer 5, Bay 7 - LBA: 0x4e931800 - SSID: 0x4 = 4 <--CRITICAL
New to NetApp?
Scan to view the article on your device
