Workload Security Data Collector 在网络故障后不会自动恢复
适用于
- Data Infrastructure Insights(DII,前称 Cloud Insights)
- 存储工作负载安全
- 之前发生过网络问题
问题
- 在
Error状态下,Data Collector 位于 Workload Security > Collectors > Data Collectors,并在临时网络故障后显示以下消息:
Connector is in error state. Service name: audit. Reason for failure: External fpolicy server terminated.
- Data Infrastructure Insights 发送警报:
Description: SVM Data Collector '<DATA_COLLECTOR_NAME>' is disconnected. The SVM is not monitored and protected.
Error: Connector is in error state. Service name: audit. Reason for failure: External fpolicy server terminated.
Data Collector name: <DATA_COLLECTOR_NAME>
dsc.log报告错误:
2023-06-29T02:32:14,874 [ERROR] [prod] [<ID>] [<DATA_COLLECTOR_ID>] [3733] [datasource-AppManager] - Service audit failed with reason: External fpolicy server terminated.
2023-06-29T02:32:14,890 [INFO] [prod] [<ID>] [<DATA_COLLECTOR_ID>] [3733] [datasource-AuditManager] - Starting a singleTimer for audit service after 15 minutes
2023-06-29T02:47:18,009 [ERROR] [prod] [<ID>] [<DATA_COLLECTOR_ID>] [3733] [datasource-AuditManager] - Exception occurred while starting : Connection error to Storage System <STORAGE_IP>: No route to host (Host unreachable)
