NetApp 计算节点已停止报告,不再更新
适用于
NetApp HCI
问题描述
- NetApp 计算节点已停止报告
- 相关 API 方法(其名称以 vCenter 开头的方法 ... )不会在 ActiveIQ 上的集群的 API 收集选项卡中进行更新
- 在尝试连接到 vCenter 时, NMA 日志的登录名无效或条目类似(可 使用文章 How to troubleshoot NetApp Monitoring Agent ( NMA ) for NetApp HCI ) can be used to check logs )
- 更改或添加 / 删除计算节点不会反映到 ActiveIQ 中
- 计算利用率部分显示空隙或为空
- HCC 上的错误 / 警报:
"code": "inventory.computeInventoryError.vcenterAuthError","message": "Error getting host information from compute service for the hosts. This could be due to an authentication error."
Some information may be unavailable because Hybrid Cloud Control can't reach one or more nodes in this installation. Please check the power state and network connectivity for all nodes and ensure in your hypervisor that the witness node virtual machine is powered on, if applicable.
One or more vCenter instances cannot be reached, causing some information to be unavailable
