跳转到主内容
H610s : NVRAM 错误消息
3,284
Visibility:
Votes:
1
Category:
h-series
Specialty:
hci
Last Updated:
适用场景
NetApp H610S 存储节点
问题描述
本文介绍了H610S节点上偶尔发生的NVRAM故障日志记录、这些故障通常会导致逐出节点的分区(元数据)驱动器
  • 此节点会记录以下NVRAM (NVDIMM)故障之一的变化:
  • NVRAM device critical={Device: 0x1000004 Key: armStatusSaveNArmed, Device: 0x1000004 Key: notEnoughEnergyForCatastrophicSave}
  • NVRAM device error={Device: 0x1000004 Key: energySourceTemperatureStatus Device: 0x1000004 CurTemp: Unknown HighTemp: Unknown LowTemp: Unknown Device: 0x1000104 CurTemp: Unknown HighTemp: Unknown LowTemp: Unknown} critical={Device: 0x1000004 Key: armStatusSaveNArmed, Device: 0x1000004 Key: notEnoughEnergyForCatastrophicSave, Device: 0x1000004 Key: warningThresholdExceeded}
  • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support.  error={Device: 0x1000004 Key: energySourceLifetimeStatus} critical={Device: 0x1000004 Key: armStatusSaveNArmed, Device: 0x1000004 Key: energySourceHardwareFailure, Device: 0x1000004 Key: energySourceHealthAssessmentError, Device: 0x1000004 Key: noEnergySourcePresent, Device: 0x1000004 Key: notEnoughEnergyForCatastrophicSave, Device: 0x1000004 Key: warningThresholdExceeded}
  • NVRAM device warning={[Device: 0x1000105, Key: 0x700cc0]}
  • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support. warning={[Device: 0x1000005, Key: 0x300cc0]} error={[Device: 0x1000005, Key: 0x800000]}
  • platformHardwareEvent: Suppressing Nvdimm status result 1/3 as false positive
  • platformHardwareEvent: Nvdimm status has stabilized after 1 failed result(s)
  • 节点的分区/元数据驱动器(驱动器0)可能会被弹出、具体取决于记录的错误以及节点正在运行的Element OS版本
如果节点正在运行
Element 10.x 分区驱动器很可能 不 会被弹出、具体取决于元件内的计时因素
Element 11.0到11.1 无论何时、分区驱动器都将被弹出
Element 11.3.0 分区驱动器 可能 会 被弹出、具体取决于所遇到的上述故障
  • NVRAM (NVDIMM)故障在5分钟内自行解决
  • 如果节点的分区/元数据驱动器(驱动器0)被弹出、 则不会 自动重新添加
注意: 如果这些警报已解决、则不需要支持部门采取进一步措施
New to NetApp?
