跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
重复发生重新启动的 SliceService 事件后,元数据驱动器将变为可用
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
适用场景
  • NetApp SolidFire
  • Element OS 11.6 或更早版本
问题描述
在 Active IQ 错误日志 / Element UI 警报中观察到以下警报:
  • driveAvailable : Node ID X has 1 available drive(s).
  • unresponsiveService : A metadata service is not responding.
  • volumesDegraded : Local replication and synchronization of the following volumes is in progress. Progress of the synchronization can be seen in the Running Tasks window.
事件日志中将显示以下事件:
  • Restarted SliceService: previous run killed with signal 6 (SIGABRT)
如果从集群中删除了足够多的元数据驱动器,或者多个分区服务同时脱机,则可能会导致卷脱机。在这种情况下,将显示以下错误日志 / 警报:
  • volumesOffline : The following volumes are offline
New to NetApp?
Scan to view the article on your device
